Glass Trim/Moulding
Glass Trim/Moulding
Postby Rick89GTS » Mon Jan 27, 2020 2:43 am
I need to reseal my quarter windows on my 1988 ST165.
What are those trim moulding pieces around the glass held on by? Are there clips or are they glued in place by some adhesive?
In the diagram, the long trim pieces are part numbers 75757, 75604, etc.
Rick89GTS
Re: Glass Trim/Moulding
Postby 93celicaconv » Mon Jan 27, 2020 10:54 pm
This.
ST165 Quarter Window
93celicaconv
Images: 26
Postby Rick89GTS » Fri Jan 31, 2020 5:22 am
OK, I missed that, I didn't drill down far enough. Thanks man!
Rick89GTS
Postby Rick89GTS » Fri Feb 14, 2020 2:54 am
For reference...
Rick89GTS
Postby Rick89GTS » Fri Feb 14, 2020 2:55 am
...i swear they are designed to break :( Definitely use an SST or universal moulding removal tool.
Rick89GTS
Postby 93celicaconv » Fri Feb 14, 2020 10:49 am
So do you have the trim pieces you need now (good ones), or are you still in need of good ones?
93celicaconv
Images: 26
Postby Rick89GTS » Fri Feb 14, 2020 11:04 pm
I have the long trim pieces but I have to order 2 new plastic mounting clips:
62765-20040
62767-20020
Gonna see if i can order SST #09806-30010 too.
Rick89GTS
Postby Rick89GTS » Fri Feb 14, 2020 11:08 pm
Maybe i can make the tool. Looks pretty simple...
Rick89GTS
Postby Rick89GTS » Fri Feb 14, 2020 11:09 pm
Worth a try!
Rick89GTS
Postby Rick89GTS » Sat Feb 15, 2020 9:23 pm
Toyota Parts Dept says they can't order it...gotta talk to Service Dept
Rick89GTS
