lalojamesliz1
This morning when I was leaving my job I started my all-trac and then when I was going to use the defroster on my windshield I noticed my clock, radio and then the blower fan wouldn't turn on. Also, I couldn't select if I wanted the blower to recirculate the air in the cabin or let smog/air in
I said whatever, I love the engine sound anyways so I drove home and used my wipers to clear the frost /moisture buildup.
I got home and began to check all of the fuses with my multimeter on the resistance setting. The one where the battery was ( battery relocated to rear) and behind both kick panels. All of the fuses are fine so I pulled each one out and pressed them back in and now everything works again WTH :shrug:
I don't know if poor contact was just the problem but do you guys have any other suggestions on what to check? I swear its always something then owning new cars gets boring :|
