https://www.youtube.com/watch?v=vray2tz ... zPfyUsuUY0
My neighbors Alltrac is having issues and doesnt want to start
Car specs: http://www.akilla.net/185/
Has new: Plugs, Wires, Distributor Cap, Distributor Rotor
Injectors were cleaned and tested Fresh tank of premium gas
Figured a car needs 3 Things to run (Air, Fuel, Spark) It cranks over Gets Spark (You can see it ark to the strut bar and on a spare old spark plug I attached to the cylinder 1 plug wire) Gets Fuel Pressure (Fuel Pump is working) Gets Signal to Injectors (Noid Tester attached to Cylinder 1 injector wire) Gets Signals to the ECU (Reads Throttle Position, & RPM) Gets Good Compression (Test Numbers Shown too! In order Cylinder 1, 2, 3, & 4)
2/13 towed the car to my house for better access
2/20 Checked the mechanical timing (crank pulley/cam gears) head and block appear to be in sync.
Fuel Pressure gauge pins itself at 47psi at the fuel rail when pump is running.
Pulled the spark plugs again. It gets spark but they are not getting saturated with fuel.
(Car has high impedance injectors, the injector resistor pack was deleted/bypassed)
2/21 injectors are getting 12v,
car cranked over for and coughed like it wanted to start for a second, but doesnt.
Engine:
2nd Gen 3S-GTE
3 Angle Valve Job
JE 9:1 0.020” Over Forged Pistons
ARP Head Studs
ARP Rod Bolts
Toyota Team Europe 1.4mm Head Gasket
ST205 Water Air Intercooler
https://www.alltrac.net/tuning/intercooler.html
TRD Radiator Cap
Hydra Nemesis Engine Management System
KO Racing Street Brawler T3/T4 46-Trim Turbo Kit
KO Racing Fuel Rail
Spec Lightweight Flywheel
Spec Stage 3 Clutch and Pressure Plate
TiAL Sport 38mm Wastegate
TiAL Sport Blow Off Valve
880cc Precision injectors
Summit Fuel Pressure Gauge
Walbro HP 255lph fuel pump
Custom 3in Exhaust By KO Racing
3in Magnaflow Resonator
3in Vibrant Exhaust
Suspension Drivetrain:
Whiteline Front Strut Bar
Whiteline Rear Sway Bar
Tein SS Coilovers
Super Pro Front Swaybar Bushings
Super Pro Rear Bushings
Mario Solid Rear Diff Mount
RC VLSD Rear Differential
Interior:
Short Shifter Kit
Recaro Reclinable Seats
Wedge Engineering Seat Sliders/Rails
Why aren't the fuel injectors firing? I tested it at the harness with a noid tester (in the past), and it seems to get a signal from there.
Engine:
2nd Gen 3S-GTE
3 Angle Valve Job
ARP Head Studs
ARP Rod Bolts
TRD Radiator Cap
KO Racing Fuel Rail
3in Vibrant Exhaust
Tein SS Coilovers
Interior:
Short Shifter Kit
