I have a ST205 3SGTE engine and are using the distributor 3 triggers for a EMU ECUmaster Classic ECU.
I am not using the distributor for sparkplug spark, all that has been deleted, just the triggers for crankshaft and
camshaft reference, Primary Trigger, Camsync. No1 and Camshaft sync. No2 Triggers.
The Distributor 3 Triggers are:- NE, G1, G2, and G- which is ground. The rotor has 24 Teeth.
The EMU Classic ECU has Primary Trigger (B7), Camsync. No 1 (B15) and Camsync. No2 (B6) in it's list of
input/output pins.
The EMU installation manual describes Camsync. No 2 as being for Variable Cam Timing or sensor on Cam 2
how ever the ST205/3SGTE engine does not have Variable Cam Timing or the such.
My problem is the ECU is getting conflicting signals from the distributor triggers.
NE is not the problem, but G1 and G2. Some trigger teeth in the graphs appear to be missing eg like tooth
No.24 or one in the middle like tooth No.16.
There appears to be a couple of options here:-
1. Join G1 and G2 together into 1 wire connected to (B15) Camsync. No1 at the ECU or
2. Cut/disconnect/disregard G2 wire. (No Camsync. No2 connection)
Looking at the ECU graphs, it looks like it may be beneficial to divide the signal into 2 lots of 12 teeth.
Can someone who has done a EMU ECU installation help me here please. What have you done to connect
the 3SGTE distributor triggers to the EMU Classic ECU?
Thank you in advance
Fred
input/output pins.
Fred
