Hey all,
I noticed that there is a bunch of oil inside of my intercooler, so I am assuming something is going wrong with the turbo. First I removed the turbo drain, and noticed the coolant drain hole had rtv blocking most of it.
Would the coolant blockage somehow cause the oil to go into the intake, or are the seals just blown?
I also took a video of the shaft play, its probably the original turbo so I am not sure if this is too much... https://youtu.be/ppqOk96ROpc
Thanks in advance for the help!
