Hi all,
My differential in my ST185 was self destructing because I believe the incorrect fluid was in there. Anyways, I drained it, but now I cannot get the fill plug off. The 12mm portion is completely stripped and gone, and I cannot get a socket around the 24mm part, because it is sitting too low in the access window thing. Is there any way to move the diff up in the mount to access that 24mm part of the bolt, or is there some voodoo magic I can use to get the plug off?
Thanks for the help guys!
P.S. can I still buy a replacement plug?
