ST185 front Wheel Bearing Seal Kit
• Page 1 of 1
Anyone know the difference between these two front wheel bearing seal kits?
04422-20060 superceded by 20080
and
04422-20020 superceded by 20110
Last time I ordered, I got the 20110 set.
This time I'm about to order, and I'm quoted the 20060 superceded by 20080 version, but the 20110 version is still current too.
and
Boosting with the '92 GT-Four RC
- 5thgenbliss
Re: ST185 front Wheel Bearing Seal Kit
No idea the difference between the two, but I did a wheel bearing job last month and successfully used 90369-38003-77 and 04422-20110.
Everything is working great with it.
Best of luck.
Best of luck.
- grip-addict
Looks like one is RH side, the other LH side. Not sure why or how they'd be different, when I replaced my ST185 wheel bearings I got the same part # for both sides and didn't see any differences between right or left.
One-TracMind - Club Member
I did one side with 20110 and seems fine. I was just curious what the 20060 now 20080 is and if its the same.
- 5thgenbliss
I purchased seal kit 04422- 20080 and it came with the ABS version of the dust ring (43246-12020) which has a taller lip and includes the cutout hole for the sensor to see through.
I also purchased just the non-abs version of the dust ring (43246-20010) out of curiosity. The lip is very short and has a longer cutout which I suspect is just for water to drain from if positioned to face downward.
After comparing the two, I decided to use the ABS version even though my car does not have ABS anymore (I installed non-abs knuckles but still have the ABS gear ring installed on the drive shafts) because the ABS dust ring would provide more protection against dust and debris in my opinion.
I believe the 04422- 20020 kit which is now superseded by 04422-20110 is the Non-ABS version of the seal kit with the smaller lipped dust ring.
This website described the difference with pictures:
https://minkara.carview.co.jp/userid/23 ... /note.aspx
Cheers
Cheers
Corey - GTFour God
- Images: 50
Thanks Corey.
That totally explains it. ABS vs non ABS. I will also do what you did; use the ABS version (20080) even though my RC also doesn't have ABS.
- 5thgenbliss
• Page 1 of 1
