The other day, the clamps holding the heater hose broke, so replace them and it fixed the leak. After that, my idle was off, car would stall. I adjusted the idle higher with the screw on the throttle body so it doesn't stall. Tried various things, unplugging the two things over the heater hoses on the fire wall, didn't change anything. Might have knock something while working on it, but can't find anything.
It is worse when cold, it doesn't even idle higher than when hot. Car runs fine otherwise, but exhaust smell like unburned gas at idle, must run super rich.
Any idea?
edit: the car is a 92 GT-Four JDM by the way.
Any idea?
