supra-raleigh
Member
On my 94 Toyota Supra Turbo, I installed an OEM Toyota coolant temperature switch on the bottom of the radiator that is rated to come on 8 degrees Celcius sooner than the original one.
The original one switches the fan on at 98 C then turns it off at 93 C while the replacement switches the fan on at 90 C and then turns it off once the coolant temperature cools to 85 C. The replacement # is 89428-33010
According to the diagram on amayama.com https://www.amayama.com/ru/catalogs/toy ... mputer-337
, this same switch will fit the All-Trac.
I think I am going to get one for my Celica.
