I'd say it’s worth it. Synthetic is a superior lubricant anyway you look at it. Since our engines are operating at higher power levels they tend to have more heat to break down normal oil, where synthetic has been engineered to withstand breakdown, reach operating ability sooner and such compared to normal oil. I love it for our Midwestern winters; it feels like its running better a lot faster in the cold weather compared to a car with regular oil. I'm pretty sure most of us use synthetic oil, though the type varies.
The main downfall would be it is a bit more expensive, but you own an AllTrac? *I'm with Gary, a signature would be a good idea to do or mention what type of car* Also it can be more prone to leaking though worn/wearing gaskets and seals. It also can be a bit hard to check since it likes to run off the dip stick a wee bit, or mine always seems to.
You can still change back if you want, it’s usually harder to go from normal to synthetic then the other way around. Since it takes a few oil changes to finally get all the normal oil removed from the engine. I'm not aware of anything ever beening damaged from swtiching oil types.
