I was driving in normal stop and go traffic, as I was shifting into second my clutch just went limp and stuck to the floor. I couldnt get the car into gear, but the car continued to run and I didnt stall. Its as if there was no pressure/fluid in there. On the side of the road I turned off the engine and when i tried to turn it on it wouldnt click, as if the clutch wasnt pressed down. After I put some pressure on it (moved it very slightly towards the ground) it started. I had to pull the clutch back up with my foot. After I pumped it for 5 minutes I finally got some pressure into it. Its been working fine since then.
I had replaced the clutch with an OEM clutch back in feb. So what I'm thinking is the master clutch cylinder is having problems. However I have no clue what it could be. So can anyone diagnose this problem for me?
