CelicaGT4":16wbr04v said:are you sure you can put the BOV on the rear of the intake manifold since it is after the throttle body(I think). But yes it will work for boost line.
Not the BOV itself, but the vacuum source for the BOV must come from somewhere behind the TB.CelicaGT4":2f0vqncg said:are you sure you can put the BOV on the rear of the intake manifold since it is after the throttle body(I think). But yes it will work for boost line.
