92' Alltrac - SOLD
I have a very clean inside and out excellent condition no rust 1992 Alltrac w/ gen4 swap 119k. asking 25k (yes I know this is high but I think this one is worth it) PM for more info
Tippo
I have the same setup :). Looks like the one in Florida a few years back. The price of the swap is nearing 10 grand now, so I'd say that's not bad for a low mileage car. Looks great.
Thanks Tippo!
Here is some additional information about the car.
Gen4 swap -
custom wiring harness from Wiregap
Timing belt as well as all engine seals and gaskets were replaced with new oem Toyota parts.
new clutch
upgraded turbo from ATS Racing - CT16 - 'Sweet 16' Turbo w/ Mamba Adj. turbo waste gate actuator
PTP Turbo Blanket for Gen 4/5 3S-GTE
AEM Tru Boost with custom pod - Controller - set to 17psi
HKS -SSQV BOV
HKS Silent Hi Power Exhaust
Runs very strong sounds amazing and doesn't leak a drop of oil.
Oil/filter changes every 2500-3000 miles with Valvoline VR1 Racing 10w-30 - Toyota Filter
Upgraded or refurbished in the last 10k miles-
New custom trans cooler lines
New one piece brake lines front to rear wheels
New reman. power steering rack
Newly rebuilt calipers and new rotors all four corners - New Porterfield R4-S pads
New flex pipe and straight pipe welded into B-pipe - cat eliminated
New exhaust hangers
Rear diff - all seals replaced - gear lash reset
All subframe and suspension bushings replaced with new polyurethane bushings
spherical bushings replaced with new OEM
New driveshaft carrier bearings
New wheel bearings and oem Toyota seals on all four corners
New Front and rear engine mount polyurethane bushings
New ball joints
New Tie Rod Ends
new sway bar end links front and rear
New sway bar bushings front
Whiteline adjustable rear sway bar and bushings
Shift linkage bushings replaced with GT4play overhaul kit - shifts like butter
New Compomotive TH1781 Wheels with Michelin Pilot Sport 4S tires
New BC Coilovers
Tachometer capacitors replaced - tacho working perfectly
AC amplifier replaced - all climate control working perfectly - ac works
Drivers side seat bottom replaced with nearly perfect junkyard gray leather seat bottom from GT-S
Interior is original gray leather in very good condition
New OEM leather shift knob
New Paint
Inside and out above and below the car is very very clean. Here are some more pictures I found
More pictures attached...
A few more pics ...
Alikazam
Worth every penny. I myself would do something different for the engine, but that's personal preference! Everything you did was exactly what needs doing on an older car and its all done for someone! Ready to go :) GLWS :)
Thanks man. I appreciate that. The car is now listed on EBay with a lower ‘Buy it Now’ price for anyone interested. If it doesn’t sell at the price I want for it I am just going to hang onto it and enjoy it.
Tippo
Just keep it! Unless there's a need to sell you'll 100% guarantee kicking yourself in 5-10 years. We've all been there. She's one of a kind now. I was about to sell Mirium and then went "wait, no... it took so long to get even a second one." I was just going to invest the money anyways - and the way I see it these are investments of their own right.
Anyways, I hope the decision is a good one regardless of the outcome. Definitely don't skirt yourself on the price, as what you did to this car was WELL within reason to hold true to the value.
Seriously keep it if you can afford to its only going to go up in value. Converting your cash back into one will be almost impossible. Respect if your just ready to move on good luck with the sale. Get what you want for it, it is worth exactly the amount you will sell it for. That is the only thing determining pricing on a car this rare, only those that own them can determine their value.
simple
Looks like you got a bid at 17k. If that is real then that is one of the highest prices yet for a ST185
That's ST205 money
simple
Huge congrats. Nice to see an engine swapped car sell for good money. Minty interior helps a ton. Hard to find good 90s Toyota leather
Luvmyalltrac
Coming from the guy who won the auction, The car IS worth what I paid. Only problem thus for is that the AC was not working. Hard to tell, in winter where she came from, but one warm day in Texas told the story. This past weekend I did a major AC overhaul and successfully got her blowing cold on demand again! I will do a post with lots of photos when time allows. Hats of to you Zunzal, for a great build! here is a couple photos with the new window tint.
