ST-185 ST-205 ST-215 parts
• Page 1 of 1
Stage3 BC cams fit Gen2 and Gen3 400
Gen4 ecu 200
Gen4 injectors 50
Gen4 Map sensor 100
Gen3 Fuel rail with 650 Sard side feeds and regulator. Will seperate.
Gen4 ecu 200
Gen4 injectors 50
Gen4 Map sensor 100
- CTechBlueDragon
- Images: 54
Re: ST-185 ST-205 ST-215 parts
I also have a full set of ST-205 brakes if anyone needs them. They go for a-lot now. Open to trades, also own a 91 MR2 if anyone has parts to trade.
- CTechBlueDragon
- Images: 54
Calipers and rotors? Front and rear?
Price? And what are you looking for in trade? OE parts or performance parts?
Wayne
1990 All Trac
Grumpy Moderator
1990 All Trac
Grumpy Moderator
- RedCelicaTRD
I don't know looks like a couple front calipers going for 650 on ebay. I don't see any rears alone.
I have all calipers and disk but I think one of the front ones may be too worn on one surface. The rears are good I used them.
Maybe like 1100 for it all...
What I am looking for:
I am trying to put together a built 5sgte for my 91 SW21 MR2.
So I am looking for aftermarket and stock parts...
153 trans or turbo axles brakes whatever
Need fuel rail and injectors for Gen2 head.
Need ct26 based downpipe.
Need a 3s/5s Fluid damper. Seem to be sold out everywhere.
Have the cams I could use if nobody buys them so maybe valve springs and retainers to work with those.
Cam gears maybe?
I also am interested in any ST-185 parts I have a 91 that is next after the MR2 is done.
pretty much anything 90s toyota cars run it by me! lol
Cam gears maybe?
- CTechBlueDragon
- Images: 54
I am interested in the brakes.
For the fuel rail is the stock side feed rail something you’re interested in?
Wayne
1990 All Trac
Grumpy Moderator
1990 All Trac
Grumpy Moderator
- RedCelicaTRD
• Page 1 of 1
