Tons of Alltrac Parts for SALE!!!!
All Trac Parts
Re: Tons of Alltrac Parts for SALE!!!!
Postby knowitalls » Mon Apr 02, 2018 2:24 pm
Interested in wastegate, turbo manifold. What size are the runners? Can you give me a little info on the manifold? does it have a t3, t4, or ct26 turbo flange?
If you didn't build it, it ain't yours.
knowitalls
Postby BAD VIBE » Fri Apr 13, 2018 11:14 pm
Do you still have cam cover?
Clutch is sold?
1990 All Trac #833 ST185 Red w/ ST205 swap - awd win
- SOLD 09... repurchased 10/14 - ST215 swap pending additional funds
1992 GTS ST184 5 speed
2012 Prius Plug-In, HOV lane Warrior
2014 Ninja 300 SE ABS the fun way to get 50-60 mpg
BAD VIBE
Postby turbo4wd » Tue Apr 24, 2018 10:11 pm
Do you have the rear diff cushion?
Dan
Undercover Moderator
turbo4wd
Postby Godzilla_juice » Tue Apr 24, 2018 11:35 pm
How much for your rear axles?
Godzilla_juice
Postby Uavinagigglem8 » Mon Apr 30, 2018 9:39 pm
hey bro,
im a year late, but do you have the driver side cabin fusebox kickpanel cover thing?
or the rear wiper arm?
still have the carbon hood? how much $?
Stick air filter box?
Thanks,
Josh
Uavinagigglem8
Postby GT4 BEAMZ » Fri Aug 10, 2018 6:00 pm
Not sure if you still have items left, but if that flywheel is available and the suspension I will take both
Thank you
GN
88 - Celica GT4 - RedTop BEAMS
94 - RX7 - single turbo
GT4 BEAMZ
Images: 2
Postby 93celicaconv » Tue Aug 21, 2018 11:02 am
Not sure this is still active or not, but do you have the brackets & bolts that support the original CAT to the engine block?
93celicaconv
Images: 26
Postby pires24843s » Mon Aug 27, 2018 8:42 pm
I'm looking for a bracket that connects the block to the transmission you can contact me at pires2484@gmail.com
pires24843s
Postby DarkoGT4 » Mon Sep 17, 2018 2:49 pm
Do you have a factory catalytic converter?
DarkoGT4
Postby 93celicaconv » Mon Sep 17, 2018 4:47 pm
DarkoGT4 wrote:Do you have a factory catalytic converter?
Assuming you are asking me this question, not the post below mine. The answer to your question is "YES".
93celicaconv
Images: 26
Postby HiuBin » Tue Feb 26, 2019 1:57 am
I realize this is an old topic but do you have the right (passenger) door available? Where are you located and what color is it?
HiuBin
Postby 90CelicaGT-S/T215 » Sat Apr 20, 2019 2:59 pm
Are any of these parts still available?
90CelicaGT-S/T215
Return to Parts For Sale
