FS: 3S-GTE Engine Part-out(s) Gen 2 and 3 WRC
All Trac Parts
Re: FS: 3S-GTE Engine Part-out(s) Gen 2 and 3 WRC
Postby Mandrew » Tue Mar 19, 2019 4:58 am
Currently, I'm not looking to disassemble the block any further. In case someone may be interested in a more complete bottom end/rotating assembly.
However, given some time if I still have it lying around I may reconsider. If you're even still in the market by then, I will keep you posted!
ToyotaFanboy wrote:You wouldn't happen to be able to give me your dipstick tube out of your generation 2 3SGTE would you? My old one broke off in the middle of my build when swapping things over. If you have a gen 2 All Trac disptick tube I could buy, that'd be great! I'm also looking for a cold air intake.
Mandrew
Postby socomstealth » Wed Mar 20, 2019 8:16 am
Do you have a spare gen 3 valve cover you'd be willing sell?
Sent from my SM-G930V using Tapatalk
socomstealth
Postby Mandrew » Wed Mar 20, 2019 12:18 pm
Someone is possibly buying the entire engine long-block, minus the cams and manifolds. If they back out, I will let you know. Probably within a week or so.
socomstealth wrote:Do you have a spare gen 3 valve cover you'd be willing sell?
Mandrew
Postby EvilStig » Thu Mar 21, 2019 6:16 am
PM'd abt the 185RC intercooler, hardlines, and inlet flange
EvilStig
Postby Mandrew » Tue Mar 26, 2019 3:30 am
Gen 2 RC intercooler is SOLD.
Mandrew
Postby socomstealth » Mon Apr 01, 2019 10:00 pm
Mandrew wrote:Someone is possibly buying the entire engine long-block, minus the cams and manifolds. If they back out, I will let you know. Probably within a week or so.
Any progress on whether this fell through or not. I'm still interested in the valve cover.
socomstealth
Postby Mandrew » Sun Apr 14, 2019 10:50 am
Still need the valve cover? Shoot me a PM.
Mandrew
Postby ToyotaFanboy » Wed May 01, 2019 5:31 pm
I’m looking for the ‘AC Thermo sensor’ on the water neck. Toyota part number is: 8862520300. If you have one, please let me know. I have pictures posted at this link: https://m.facebook.com/groups/197062610 ... 8314904080
ToyotaFanboy
Postby mpg » Thu May 02, 2019 7:58 pm
Do you have the power steering pump complete?
mpg
Images: 13
Postby ToyotaFanboy » Thu May 02, 2019 8:55 pm
mpg wrote:Do you have the power steering pump complete?
I know I’m not the OP, but I just figured I’d let you know that I just bought a reman PS pump for my All trac on Rockauto about a month ago. I just sent back the core 2 days ago.
ToyotaFanboy
Postby Mandrew » Thu May 02, 2019 9:13 pm
I have a power steering pump for both a gen 2 and 3, but depends on your definition of "complete". It's all there except the lines have been chopped by the engine importers. If your lines are still intact, should bolt right up and work just fine.
Mandrew
Postby Mandrew » Thu May 02, 2019 9:18 pm
ToyotaFanboy wrote:I’m looking for the ‘AC Thermo sensor’ on the water neck. Toyota part number is: 8862520300. If you have one, please let me know. I have pictures posted at this link: https://m.facebook.com/groups/197062610 ... 8314904080
For a gen 2 or 3?
Mandrew
Postby 93celicaconv » Thu May 02, 2019 11:33 pm
In the link you provided, the same picture shows up on RockAuto.com as Four Seasons P/N 37989 for $43.89 - only 7 remaining in inventory. If you are sure what you need is in that RockAuto pic you have on Facebook, then this item is likely it.
93celicaconv
Images: 26
Postby ToyotaFanboy » Fri May 03, 2019 1:58 am
For a gen 2 or 3?
Gen 2
ToyotaFanboy
Postby ToyotaFanboy » Fri May 03, 2019 2:00 am
Damn man! Thank you so much! I can’t even explain how much I appreciate it. Thank you!
ToyotaFanboy
Return to Parts For Sale
