**SOLD** 2nd Gen 3sgte Full Motor $650
**SOLD**
Out of Lazarus.
Item: 1992 Toyota Celica All-Trac Turbo 3sgte motor
Item Condition: Fair, stopped running in March 2022, still mechanically sound for a rebuild
Price: $650
Extra Info: Complete motor including turbo, exhaust and intake manifolds, sensors, etc etc
Preferred Contact Method: PM or reply, can get phone # in DMs
Pictures: Attached.
Motor was in car. Car sat from 2007 --> 2020 when I got it running again. Ran it a few hundred miles after 3x oil changes, put in an alternator and some various parts. Started for the first time after the winter, drove about 1/4 mile and car stopped. Immediately parked, purchased a 4th gen 3sgte motor and that was installed.
Following swap, took off timing cover, timing belt was still in tact. Motor still rotates cleanly from starter and crank and has compression.
Was driven by an elderly man until his death in 2007, was taken care of by Torrington Toyota otherwise. Motor is original to car with 272k on it.
Would recommend using this as a high HP build and going through the entire machine rather than swapping blindly into another machine based on the fact it sat for 13 years.
As mentioned, local pickup only.
Out of Lazarus.
Price: $650
Pictures: Attached.
