swap finally started (finished)
Postby 93celiconvertible » Wed Apr 20, 2005 4:39 pm
yes finally its time to swap the motor....3sgte into st184...i will post pictures of the progress.
pictures on cardomain.com username bongbbreakin
Last edited by 93celiconvertible on Wed Aug 10, 2005 4:22 pm, edited 1 time in total.
2nd gen jdm 3sgte swapped st-184
00 gpw ap1 stock
93celiconvertible
Re: swap finally started
Postby 3sgte@daspeedof » Sun May 29, 2005 6:09 am
93celiconvertible wrote:yes finally its time to swap the motor....3sgte into st184...i will post pictures of the progress.
^^^I'd like to see that. I am just starting to pull my 5sfe engine out this weekend. I'm gonna be putting a 1st gen 3sgte into it.
Alltrac hood, carcept sides, erubuni front lip
3sgte swapped celi
A boosted Celica is fun, Seeing the look on someones face when they get left by a car that is primered is priceless
3sgte@daspeedof
Postby 93celiconvertible » Mon May 30, 2005 4:01 am
let me know if you have any questions, i finished mine bout 2 weeks ago and havent had time to sit down and scan pics and do all that thought, ive been having fun with it htough.
00 gpw ap1 stock
93celiconvertible
Postby gt litfhback » Mon Aug 08, 2005 6:34 pm
awesome guys ................i am thinking on putting the II gen on my celi but at the time of buying this engine what should i look for. besides the ecu...lol what should the compression on that engine be....and other stuff i migh need for the swap thanks for the info
gt litfhback
Postby 93celiconvertible » Wed Aug 10, 2005 4:26 pm
besides the ecu you should be looking for
a 3s harness that isn't cut
AFM
turbo pressure sensor
shaft play on the turbo
if it has been compression tested and leak down tested
look at japandomesticmotor.com they are awesome thats where i bought my jdm 3s i asked those questions and they are good
my main harness wasn't cut it was comp. and leak tested the turbo has little to no shaft play just like how they said
they told me that i needed to get an afm and a tps though but i got those from a buddy for free so im happy.
00 gpw ap1 stock
93celiconvertible
Return to FWD Celica
