Head Removal In Car Write Up
Postby bluemonkey » Thu Nov 13, 2008 10:12 pm
I took off a bunch of items, still got the dist. and timing belt on there. Figure I'll wait so i can have a friend help. Can I just mark the dist and then pop it back in or just leave it on the head? Timing parts scare me lol.
2 weirds things i noticed
white residue on the valves, and
there actually was a bit of coolant in the spark plug hole once i pulled the valve cover.
bluemonkey
Postby tw2 » Thu Nov 13, 2008 10:37 pm
If you mean the water neck by the distributor then you should just be able to pull the hoses and electrical connectors off.
Thomas, JDM 90 185, 06 350z
tw2
Postby bluemonkey » Thu Nov 13, 2008 11:19 pm
I took that off already, I was talking about teh actual distributor. What issues may arise if I leave it there?
How the heck did you manage to cut off the braces on the back of the intake manifold? I tried unbolting them but that didn't work out very well.
bluemonkey
Postby tw2 » Fri Nov 14, 2008 12:38 am
You can leave it there. The only thing I can think of is if it somehow gets damaged. Hahah well.... I got a hacksaw blade, wrapped a little but of electrical tape around one end to save my hands and cut it with that. Took about 20-30 minutes to do one stay. Those bolts are really hard to get a good spanner on and you should soak them with PB blaster or similar. I managed to get all sorts of combinations of sockets and wrenches behind the engine to get the side stay off. But the one closer to the middle there really is not enough room.
tw2
Postby bluemonkey » Fri Nov 14, 2008 5:34 am
Yeah I tried reaching through an opening by the passenger wheel for the bottom one but no luck. I'll give it another try tomorrow and then the hacksaw will come out. I had like 3 sockets, 2 ratches, 2 wrenches, but I couldn't get one on there that allowed any movement without bumping into something. I need to figure out exactly how I'm gonna give the timing belt tension so that I don't have to remove the bottom pulley to set the timing belt again.
bluemonkey
Postby tw2 » Fri Nov 14, 2008 6:17 am
You don't need to get the bottom pulley off to set timing. Getting past the two stays was by far the hardest part of the rebuild for me. I found I had ok access through the wheel well for the closest one.
tw2
Postby bluemonkey » Fri Nov 14, 2008 12:36 pm
no I was referring to keeping tension on the belt so that the bottom pulley didn't jump any teeth. The BGB says you have to remove the pulley to put the belt back on if you do take it off all the way. Is there a way to do it without removing that pulley?
I know if I keep tension on it, I'll be able to just put it back over the cam gears and have it marked so I get it in the right position. But if it jumps teeth, your supposed to take off the pulley to get the bottom cover off.
bluemonkey
Postby tw2 » Fri Nov 14, 2008 8:52 pm
You could try clamping it together with a strong paper bulldog clip. Otherwise just count the notches between the cam gears and make sure the non-tensioner side is taught. I have never bothered to stop the crank jumping teeth and have never had to redo my timing after pulling the pin. You might have to ask someone else how they did it; I have never done it that way.
tw2
Postby bluemonkey » Sat Nov 15, 2008 4:19 pm
So what did you do with the belt after you loosened up the tensioner and removed it from the cam gears? Just let it dangle to the side and it didn't jump any teeth at the crank?
My head looks pretty clean minus the small amount of coolant/oil.
http://gallery.me.com/jehime/100004...=12267700730001
http://gallery.me.com/jehime/100004...=12267700540001
parade=sandwich bags I'm using to sort out the bolts lol.
bluemonkey
Postby tw2 » Sat Nov 15, 2008 6:52 pm
One of the times I did it, it just happened to not jump any teeth. The second time it did and I just pulled it forward so it wasn't kinked or in the way at all.
Heres a good tip, to get the tensioner back in, tie some string to the pulley it pushes on. Tie this tightly to something in front of it, it makes it very easy to get back in.
Can't see pics sorry but good work all the same.
tw2
Postby bluemonkey » Sun Nov 16, 2008 2:33 am
Oh, I'll re-upload them when I get home. Would a small zip tie fit on the tensioner like you said? If not, maybe I'll pull some fish line through it and zip tie that. The timing belt will probably be zip tied to something as well. I don't want to have to go further into taking it apart since I'm doing this at an apt. complex lol. I'm going to take the plunge tomorrow so wish me luck and post any advice as I'll probably be going online to check the BGB for details that I may have skipped since I just went in after reading over but not actually following the directions since its in the car and I don't want to take off anything I don't have to.
bluemonkey
Postby Rick89GTS » Sun Nov 16, 2008 3:35 am
Great write-up :D Kudos!
Rick89GTS
Postby tw2 » Sun Nov 16, 2008 4:15 am
bluemonkey wrote:Would a small zip tie fit on the tensioner like you said?
Maybe a large one, I used string, fishing line would work well. When I did it I loosened the pulley bolt 1-2mm to fit the string around it and pulled it forwards quite hard before tying it off. Before discovering this trick it was not a lot of fun. Just make sure you torque it back up correctly if you do decide to do it that way.
Rick89GTS wrote:Great write-up :D Kudos!
Thanks
tw2
Postby bluemonkey » Sun Nov 16, 2008 4:30 am
try this for the pictures
http://idisk.mac.com/jehime-Public?view=web
I have some small clamps that I may try to use, figure they might make it a lot easier.
bluemonkey
Postby tw2 » Sun Nov 16, 2008 8:03 am
Wow thats pretty clean. What cams are those? I find photobucket is easiest for pics, then just copy the code it gives you with [img] tags.
tw2
Return to FAQ / Archive
