BLOWNTACO":2mxruczu said:There isn't any from I could find. The only way to get the clips is buy another one. Nice huh?
damn! well that sucks
Nitro_Alltrac":301t4ywf said:I found these numbers on the very first page but I'm not sure which one is the one I need. I am needing the number for the two washer/gaskets that go on the turbo oil feed line where it attaches to the block. There is one on the top and one of the bottom of the banjo fitting. The numbers I found are:
gasket, joint for turbo oil pipe - 15526-88381
Turbo oil line gasket - 15471-88580
Which one is correct for what I need?
Thanks.
Can anyone answer the question on these? I really need to get a couple.
Thanks.
Conan":34kqynna said:Gary, you filthy pirate!
31410-20510 CYLINDER ASSY, CLUTCH MASTERdeceit":nget22q1 said:anyone know the part numbers for a 91 ST185 RHD for a clutch master cylinder and clutch slave cylinder??
That's the cheapest option.Tazka":1rp1125h said:Can you guys confirm if this is CS bumper cover code:
52119-20926
Gary ST165":2p1783td said:Conan":2p1783td said:Gary, you filthy pirate!
Every GT-Four / Celica Turbo 4WD / All-Trac owner should download the EPC.
It is invaluable and should be the 1st mod, before spending a dollar on the car :lol:
