[Toyota Part Numbers]
Postby 88st165 » Sat May 12, 2007 10:51 pm
those toyota exhaust mani gaskets are expensive compaired to a felpro exhaust manifold gasket which i have been using for a year with no leaks whatsoever... but i did also get the manifold resurfaced....
come to think of it, that is the only gasket i have used that was not toyota ...
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby alltracshoak » Tue May 22, 2007 6:17 pm
Austen_gt4 wrote:valve cover gasket -11214-88381 inner
-11213-88381 outer
is the inner the one between cylinder 2 & 3 valve cover gasket?just making sure
Current 1992 teal st185- 2018 - in pieces trying to pit back together
90 black st185 - 2018 - sold 2018
90 black st185 -sold 2010?
rip: 92 white st185 @ 178k :(
alltracshoak
Postby theft and recovery » Tue May 29, 2007 4:45 am
whats the part no for the non calros seinz gt4 hood(1990)? mines damaged.
Why is it hard to convince people that standing in a freezing forest for hours to see a car blast past every couple of minutes is fun? Rally a real test for cars!
theft and recovery
Postby muneo » Thu May 31, 2007 7:14 am
Does anyone have the part number to this?
55mm air intake connector(rubber part that bolts to the TB)
Someone gave a part number for the st185 50mm but not the 165 55mm one.
Ex-185 Owner
muneo
Postby muneo » Thu May 31, 2007 7:17 am
Also,
I think Tim listed these as the system 10 door emblems/plates:
67638C - RH
67639C - LH
They dont show up when I type in the part numbers for 1stToyotaParts.com
Are these the complete part numbers?
Ex-185 Owner
muneo
Postby Conan » Thu May 31, 2007 7:24 am
muneo wrote:Someone gave a part number for the st185 50mm but not the 165 55mm one.
17861-88381 CONNECTOR, INTAKE AIR 3SGTE..ST165
Conan
Postby Conan » Thu May 31, 2007 7:29 am
muneo wrote:Are these the complete part numbers?
No, just reference numbers.
67638-20040 PLATE, FRONT DOOR TRIM, NO.2 RH
67639-20040 PLATE, FRONT DOOR TRIM, NO.2 LH
Conan
Postby muneo » Thu May 31, 2007 7:32 pm
Thanks Conan!
Besides this thread, is there a Master List somewhere?
Ex-185 Owner
muneo
Postby Denver_whiteST185 » Fri Jun 15, 2007 8:34 am
conan, can you get me the part numbers for these 4 pieces. they are off my ST205 brakes, and they've seen better days, so i would like to replace them.
on the caliper
Thanks buddy :D
^Ted^
Denver_whiteST185
Postby Conan » Fri Jun 15, 2007 9:01 am
Denver_whiteST185 wrote:conan, can you get me the part numbers for these 4 pieces.
90240-06019 PIN, W/HOLE (FOR FRONT DISC BRAKE ANTIRATTLE)
90468-12022 CLIP (FOR FRONT DISC BRAKE ANTIRATTLE)
47748-14080 SPRING, ANTI-RATTLE, NO.2 (FOR FRONT DISC BRAKE)
Conan
Postby Denver_whiteST185 » Fri Jun 15, 2007 9:13 am
SWEEEET!!!
that was fast :P
I forgot to ask, also whats the part number for the little o-rings that go between the two halfs of the calipers to seal off the hydrolic fluids?
^Ted^
Denver_whiteST185
Postby 88st165 » Fri Jun 15, 2007 12:21 pm
anyone have the part numbers for the front most fender trim on a non-U.S. st165?
for U.S. models it has the cut out side marker, but for non-U.S. it is solid b/c the sidemarker is located up and to the rear of the fender...
Black st165 - gone
88st165
Images: 2
Postby Conan » Fri Jun 15, 2007 3:13 pm
Denver_whiteST185 wrote:I forgot to ask, also whats the part number for the little o-rings that go between the two halfs of the calipers to seal off the hydrolic fluids?
47731A?
Conan
NT
Postby Gary ST165 » Tue Jun 26, 2007 4:50 pm
88st165 wrote:anyone have the part numbers for the front most fender trim on a non-U.S. st165?
no longer available new from Toyota Japan :(
75611-20440 MOULDING, FRONT FENDER, OUTSIDE FRONT RH
75612-20410 MOULDING, FRONT FENDER, OUTSIDE FRONT LH
ST165 turbo 4WD
Gary ST165
Postby Conan » Tue Jun 26, 2007 4:54 pm
No Spin wrote:I made a thread on this elsewhere, but this seems an appropriate place for the part # if someone has it
44204-20170 RACK SUB-ASSY, POWER STEERING
Doesn't look like it comes with any rods though.
Now, where do we meet for beer? :) Actually, if you pay for the plane tickets I will come personally with a brand new steering rack in my hand for free! :twisted:
Conan
Return to FAQ / Archive
