Differences in 185 and 165 motor?
Postby Jvimpty » Thu Feb 10, 2005 12:14 am
Does anybody know what the differences are in the 3sGTE in the ST185 and the ST165 (1988)?
Will the bottom end of a 185 motor bolt to a 165 Head? are there any differences?
Will this change compression etc?
Jeremy
Jvimpty
Postby Gary » Thu Feb 10, 2005 3:26 am
If you do the search, you should come up with this
http://www.alltrac.net/phpBB2/viewtopic.php?t=4217
93 ST185
Gary
I fouind that but the answer didn't seem that clear..
Postby Jvimpty » Thu Feb 10, 2005 1:09 pm
What about bolting a 165 head to a 185 block...
I don't know what gen the motors are? is teh 165 motor (1988) a gen 2?
and teh 185 a gen 3 motor?
Sorry for my ignorance
Thanks for any help...
Oil and H20 passages teh same on the above? compression ratio changes?
Jeremy
Jvimpty
Postby saved_1992 » Thu Feb 10, 2005 1:33 pm
1GEN is 88-89,2gen 90-93, 3gen is 94-99?, 4gen over 99?
the 1 gen head will fit on the 2gen block
if you want to upgrade cams the 2 gen has alot more aftermaket kits.
oil and cooling the same compression the same or very close.
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby Gary » Thu Feb 10, 2005 4:27 pm
If you put 1st gen, head on 2nd gen block and if you have 9-stud exhaust manifold, you will have to grind/cut it to fit 1st gen head.
93 ST185
Gary
Postby Ervin_S » Thu Feb 10, 2005 11:05 pm
Just get an whole 185 engine :shrug:
88 Celica Alltrac- Sold to Andrew :(
Ervin_S
Postby Austen_gt4 » Thu Feb 10, 2005 11:33 pm
jeremy has the whole motor 2nd gen, he has a bad block in a 165. he wants to put the 185 block into it. he needs to know if the oil cooler and any other lines will need to be moved or relocated.. i dunno if he wants to put the whole 185 motor into it. right now on the 165 he has a t3/t4 and a tec3 (i think) and it's all tuned for the 165 motor.. soo what he want to do is just swap bottom ends. and all he wants to know if any major problems are going to come up. oil cooler ect.
i hope that clears it up some..of what your trying to do jeremy.
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Thanks Austen
Postby Jvimpty » Fri Feb 11, 2005 1:02 pm
Yeah basically trying to get a street car running as cheap as possible.
threw a rod....in 165 motor...I have a bunch of 165 heads....and one "good" 185 bottom end....
just wanted make sure that bolting this combo together was possible and didn't drop compresson...or need some other special somethings done..
Thanks for the info/help.
Jeremy
Jvimpty
Postby saved_1992 » Fri Feb 11, 2005 1:10 pm
i do believe the flywheels have a different bolt pattern. the oil cooler/lines are different.
mike
omaha,ne
saved_1992
Postby layzienoy » Tue Feb 15, 2005 11:59 pm
i believe that the second gen.s have a slightly higher compression
layzienoy
Return to FAQ / Archive
