5x114.3 front and rear.
Re: 5x114.3 front and rear.
Postby camry90 » Thu Oct 31, 2013 6:05 am
Great news or horrible news?
camry90
Postby tubasteve » Sat Nov 02, 2013 8:48 pm
Very bad news, star test for smog. I like legal smogs, but that's another topic
tubasteve
Postby camry90 » Sun Dec 15, 2013 4:55 am
so why you SSSSHIIIITTTTTT for if it has nothing to do with this topic? much attention?
so are you still waiting for someone to pay you for your info?
camry90
Postby Bill Strong » Mon Dec 30, 2013 2:23 am
I have a dead st165 all trac.
I endurance road race a 1991 v6 mr2 using supra front brakes and rx8 front disks on the rear.
Converted rear splines to Camry so I can easily and cheaply get axles.
So now need another endurance race car.
88 all trac. 3mz v6 powered. That is the easy bit.
I need to be able to use the same wheels 17x9 +25 with 4x 265 40 17 tires that I use on the mr2 to keep cost and spares down.
Saw this thread via google.
So.. Brakes.
Need 5x114.3 pcd. Would like to use the same brake setup as well. But that is the easy part.
Or have you found an easier more available setup? I just purchased $3500 worth of mr2 racing brake pads for 2014. Would be nice to be able to use the same setup lol....
So before I dig into RockAuto and sort out the hubs and get an over the counter brake system built using my mr2 gear on the st165, what info do you have that can get me a good reliable braking system that will last 24 hours like my v6 mr2 setup?
Bill Strong
Founder - The MR2 Owners Club Message Board
http://www.mr2oc.com | http://www.v8mr2.com | http://www.racingstrong.com
1988 Celica All-Trac | 1991 MR2 GTv6 | 1986 V8 MR2 | 2001 MR2 Spyder GTv6
Bill Strong
Postby Bill Strong » Mon Dec 30, 2013 3:17 am
So I cross referenced rockauto and a few other sources.
Fronts are rav4. I know these fit as they are what we use to convert mk1 mr2 to 5x114.3 pcd. $50 each at rockauto. I have a stack of them. So no costs.
Rears are highlander hubs. Just strip them and they will fit the alltrac bearing. Is this right? They have the same spline as the alltrac rear axles? $44 each at rockauto. Hella cheap.
Bill Strong
Bill Strong
Postby Cuttyman9 » Sun Apr 13, 2014 4:27 am
I have no experience with the back hubs but the front hubs are definitely rav4.
I saw on toyodiy that it said front and rear alltrac bearings use the same part number, might be worth checking if the alltrac spline rear axle and bearing ID are the same as the OD of the rav4 hub just to check.
Brake wise there is tons of different stuff haha I run stoptechs (st40 calipers off an evo) with is350 rotors
1992 Celica GT Hatch
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby aus jd 2703 » Tue Dec 09, 2014 3:08 am
really stupid quick question,
is there any reason we cannot bore out and re drill to the 114.3mm pcd standard Toyota rotors?
seems easier than buying new rotors.
aus jd 2703
Postby DeeCee » Wed Dec 10, 2014 9:44 pm
IMO - there is a lack of surface area on the face of the rotor to safely re-drill to 5x114.3 mainly due to the handbrake adjustment hole being located between two stud points.
DeeCee
Postby krishna » Thu Jun 08, 2017 4:08 pm
hi there does any one have pictures on this convertion???????
cheers Kris....
krishna
1985 Toyota Corolla
Postby Cuttyman9 » Thu Jun 08, 2017 6:22 pm
5thgencelica.com has a full writeup for both Alltrac and fwd
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby krishna » Thu Jun 08, 2017 7:56 pm
will check it out after i regester to the page
tnkss for the info.....
krishna
1985 Toyota Corolla
Return to FAQ / Archive
