Door Sensor
Door Sensor
Postby -==L=a=N=c=E==- » Mon Aug 16, 2004 2:45 am
With my car, the left and right door sensors don't work anymore. But the rear hatch works just fine. What would be the problem... a bad ground or something? Anyone know how the wiring works for them?
-==L=a=N=c=E==-
Postby Gary » Mon Aug 16, 2004 2:55 am
I would suspect the door switch first.
I think it's common failure on 5th gen Celica.
93 ST185
Gary
Re: Door Sensor
Postby Rick89GTS » Mon Aug 16, 2004 6:20 am
-==L=a=N=c=E==- wrote:With my car, the left and right door sensors don't work anymore......
Count your blessings, no more beep, beep, beep , beep...
Rick89GTS
Postby -==L=a=N=c=E==- » Mon Aug 16, 2004 10:29 am
Gary: Cheers, ill double check wiring etc when i get a chance...
Rick89GTS: Beep that it may, i want my auto cabin light :)
-==L=a=N=c=E==-
Postby mototebok » Mon Aug 16, 2004 10:40 am
I could use a pair of them as well.... Anyone know offhand how much Toyota rapes us for them?
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby Rick89GTS » Mon Aug 16, 2004 6:23 pm
mototebok wrote:I could use a pair of them as well.... Anyone know offhand how much Toyota rapes us for them?
Moto: Just go the wrecker's, they gotta be the same as the n/a Celicas
Lance: ok, I forgot about the cabin light :doh:
Rick89GTS
Postby Fastrac » Tue Aug 24, 2004 2:34 am
The odds are you don't need to replace them. The right one on my car stopped working. To fix it all I did was: Remove the bolt (10mm I think) and pull out the switch. Take the rubber cover the switch itself. Take some WD-40 or contact cleaner and soak the switch. Work the switch in and out. You will get alot of black WD-40 coming out. Keep working the switch and spraying WD-40 in it. After a while it will be cleaned out and work. Just put it back in and make sure the bolt is tight. That is the ground it uses to make the circuit complete.
Fastrac
Postby Rick89GTS » Tue Aug 24, 2004 5:22 am
There some on ebay right now. Don't have the link though...
Rick89GTS
Postby dianaspicer » Tue Aug 24, 2004 1:03 pm
There are always plenty on ebay.
Thanks,
Diana
1990 ST185 (RED TRAC) - Mine
1990 ST185 (BLK TRAC) - Mine
1988 ST165 (GRY TRAC) - Fathers
dianaspicer
Postby -==L=a=N=c=E==- » Tue Aug 24, 2004 1:08 pm
Ill try the WD40 trick tommorrow see if it works. Do i have to remove the inside panel to get to it, or can i just remove the rubber piece and pull it out of the door that way?
-==L=a=N=c=E==-
Postby Guest » Tue Aug 24, 2004 5:16 pm
Just peel back the rubber over the bolt and remove the bolt. Then carefully pull the switch out. After it is out you can totally remove the rubber cover and work on the switch. Keep in mind that you will still have the wire connected inside the car. There should be 6 or 8 inches of slack for you to work with though.
Guest
