ST162 Cluster into ST165
Postby killemalltrac » Wed Nov 27, 2013 3:53 pm
Before I do this I was wondering if anyone had done it or knew if it would work. I would like to delete the factory boost gauge and also use the voltage meter in the 162 cluster if possible. I am planing to finish stripping my parts car (ST162) this week and the cluster is one of the things I have been excited for.
#80sMurderCar
My build -- http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=47568
Parts for sale -- http://www.80smurdercar.com/store/c1/Featured_Products.html
killemalltrac
Images: 10
Re: ST162 Cluster into ST165
Postby 88gt4DE » Thu Nov 28, 2013 2:26 am
I'm fairly positive they are. Although I haven't done it ... Have one and thought about it but just left it alone. I'm sure someone else out there has ...
2000 Toyota Tundra SR5 - 165K - Thanks 97JZA80
2008 Toyota Avalon - 110K - DD - Work Runner
2007 Toyota Rav4 - 145K - Wifey DD
Postby fwame_dwagon » Thu Nov 28, 2013 3:10 am
Ive always thought about doing this on my 185. Maybe even using an MR2 cluster so I can mount a gauge in it like many people do.
fwame_dwagon
Postby Rick89GTS » Fri Nov 29, 2013 7:47 pm
You would have to hook up the voltage meter senders. I know over at Celicatech.com, Chris D, has done a fair amount of work fitting aftermarket gauges into the stock 162/165 cluster. You may want to d oa search for this threads.
Rick89GTS
Postby alltracandahalf » Tue Sep 15, 2020 5:35 pm
It's easily doable, just unhook the 165 dash electrical connectors and hook up the 162 dash no mods necessary
alltracandahalf
