Head light motor issue
Postby shifrerm » Thu Dec 10, 2015 6:40 am
Hey everyone I got a ST162 with a pair of headlights that don't want to operate when the switch is turned on or off, both motors work and turn with the red knob under the rubber boot. So heres a run down of what I've done so far
-Replaced RTR 30a fuse in engine room fuse box
-Replaced HEAD relay in engine room fuse box
-Replaced both headlight fuses in engine room fuse box
-Replaced the "blue box" headlight retractor control relay with the one from my ST165 (which works fine in there)
-Checked the ground on the right fender
-Checked both fusible links by the top of the + battery terminal
I know Im getting power up to the point of the blue box because I can here it click when I flick the switch. my head lights come on as well so I don't think it could be the fusible links either. Im running out of ideas if anyone has any suggestions please feel free to let me know! I also have the official wiring diagram book for my car so I can refer things off that.
Also its a 1989 Celica GT-S with the 2.0L 3S-GE
shifrerm
Re: Head light motor issue
Postby corax » Thu Dec 10, 2015 9:31 pm
Not sure if this is your problem, but try following the directions in this link to clean the contacts inside the motor: http://www.clarks-garage.com/shop-manual/elect-21.htm
The biggest part to pay attention to is the bit about the contact disc, your motor will look a bit different than the pics this guy put up
Keith
SE PDX, Oregon
'88 ST165, '85 RA64, '88 RN61
corax
