What does this instrument light mean?
Postby MatPop86 » Thu Jun 18, 2020 3:02 am
Just got my ST165 running, what does the car with the lines behind it symbol mean?
MatPop86
Re: What does this instrument light mean?
Postby underscore » Thu Jun 18, 2020 6:08 am
One of the rear lights is burned out.
Postby alltracman78 » Sun Jun 21, 2020 4:09 pm
The modules go bad sometimes. And the wiring harness where it flexes in the trunk.
But start with the bulbs like he said, that's the easiest thing.
Make sure it's the right bulb. And the same as the others.
Those systems can be more finicky than an insecure pregnant wife....
*Should probably explain what that is, huh.
Your car has a circuit that checks for a difference (can't remember if it's current or voltage) between the rear bulbs. If it sees a difference it turns that light on. It's supposed to mean you have a rear bulb out. But the cars are so old now other parts of the circuit malfunction a lot of the time. So start by checking your rear bulbs. Hopefully one is burned out and it's an easy fix. If not, check the stuff I mentioned. Start by making sure all the bulbs are the same and there's no corrision.*
Postby Rick89GTS » Mon Jun 29, 2020 6:07 am
Also take a look at the contact points where the bayonet bulb sits in. Sometimes the contacts wear down over time causing funny issues. I had to splice a newer one into mine.
Rick89GTS
Postby FC Zach » Mon Jun 29, 2020 10:21 pm
MatPop86 wrote:what does the car with the lines behind it symbol mean?
Thrusters engaged! :D
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby MatPop86 » Mon Jun 29, 2020 10:22 pm
Ludicrous speed - GO!
MatPop86
Postby 88gt4DE » Sun Jul 05, 2020 6:45 pm
:rofl:
2000 Toyota Tundra SR5 - 165K - Thanks 97JZA80
2003 Toyota Camry - 165K - DD - Highway Runner
2007 Toyota Rav4 - 145K - My girls DD
