help! i already bought a new headlamp but thats not the problem. i metered the wiring with a voltmeter and the voltage is low ( around 4-8 volts which should be around 12volts). i check and metered the headlamp relay and thats good 12volts. do i have bad wiring or is there something else i can replace or check? has any one had this issue?
