First try on 402m with my st165 daily driver
Postby sleeper » Mon Jun 08, 2009 3:33 pm
Had a road trip with my st165 this weekend and did some drag runs
( The trip was a 500miles road trip, so had to be 100% shure that the car would hold togetter )
So for the specs:
This car is a daily driver that i use to drive to work, and nothing have been changed on the car when i ran this weekend.
normal street tyres ( 225\40\16 280 treadware)
No trackbite ( old flightstrip, that only got used for drag racing this one time)
Stiff suspension setup.
Removed some weight, ( rear seats, lightweight bucket front seats+++)
Results:
60: 1.95
1\8 : 7.4241
1\8 mhp: 104.47
1\4: 11.1619
1\4 mph: 132,6 ( rev limiter last 30 meters)
( i will post time slip as soon as i can figure out how to post pictures :D )'
My goal was to do a 10 sec run on 100% street setup and tires, but i could not get the 60 down any lower than that, but will make one more try on another track with better grip and get that 10:-)
sleeper
Postby Mafix » Mon Jun 08, 2009 3:34 pm
now i have to go find your spec sheet. amazing time.
Postby vip09 » Mon Jun 08, 2009 3:41 pm
Impressive! Mod list?
vip09
Postby Mafix » Mon Jun 08, 2009 3:43 pm
yep can't find a posted mod list.
Postby sleeper » Mon Jun 08, 2009 4:36 pm
Here is some more pictures of the car, it`s not a complete mod list there, but you`ll get the idea.
( The small version of the list is:
5sgte ( 3s crank and rods with custom 88mm pistons)
sc6262 turbo
autronic ems
1600cc injectors
clutchmasters fx700
rmr intake
hks 256 cams
e85
30psi
+ hunderds of other small things.. just ask in the other tread if you whan`t to know anything..
sleeper
Postby Mafix » Mon Jun 08, 2009 4:52 pm
oh yeah. very nice.
not a bad turbo for a dd. what a/r did you go with.
Postby sleeper » Mon Jun 08, 2009 5:18 pm
it`s a t3 83ar exhaust, full boost at about 4700-4800 in 4`th
( also must ad that the car only got a stock st165 rear diff ( open diff)
So trackion was really a problem, did not have tracking before 3 gear.) )
just took some pictures of the car as it sits now and the time slip but don`T know how to post pictures.. anyone got a good guide?
sleeper
Postby smog7 » Mon Jun 08, 2009 11:38 pm
nice! that's pretty damn fast
-omar
rally tarmac 1990 st185
smog7
Postby Klas » Tue Jun 09, 2009 6:10 am
Nice to see another fast st165 out there 8)
Would be fun to see your car in person sometime.
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby vip09 » Fri Jun 12, 2009 2:59 pm
30+psi on E85! Nice! I'm only running 20psi on my E85 setup right now.
How much ignition timing are you running in boost? What AFR?
vip09
Postby sleeper » Fri Jun 12, 2009 3:35 pm
30psi is no problem on e85, at least not on that large turbo.. not much back pressure with it..
afr was 11.5 on that run, but have adjusted it down to 12 now.. so i should have a few more ponies now,
timing is at about 15-16 at 30psi. no knock at all..
sleeper
Postby LegacyofDan » Fri Jun 12, 2009 3:38 pm
that same slick red 165 of yours?
Postby sleeper » Fri Jun 12, 2009 3:50 pm
LegacyofDan wrote:that same slick red 165 of yours?
yes, it is the same car :-)
going to get that 10 on those bad street tires, and then i`ll see what it can do on slicks.. hoping i will get it down to 10.3-10.4 with slicks.
( but i guess that will take some time to get since i only got 2 days in a year that we are aloved to run 402m with street cars here in norway.'
And with no roll cage i will be baned after 2 runs under 12 sec... :lol:
sleeper
Return to Racing Chat
