Towels first 1/4 mile run!
• Page 1 of 2 • 1, 2
Sorry this is a little less content than I would have liked. But I'm just too excited to wait.
I have videos, pictures, and time slips that I'll be posting.
Car Mods
1993 Celica Alltrac
215,000 Miles on stock** internals
50k approx on the clutch
Greddy td06 20g at anywhere from 10psi to 15psi. (boost creep)
Greddy downpipe
3" Exausht w/ HKS Silent Hi-Power
Cheap FMIC with 2.25" piping
ASI 50mm aluminum w/ 9" spal fan
Relocated battery.
Khumo super high performance streets tires, at 45psi on Celica GT-S 00+ rims
Full interior, 12" sub and amp.
QM Time on my last run was 13.65!
Not too shabby, pics and vids and time slip scan to come. Though my reaction time was god awful... the lights were really funky on the last run.
-Towels
Car Mods
1993 Celica Alltrac
Greddy downpipe
Relocated battery.
-Towels
2003 S2000
1985 300TD
1985 300TD
WarTowels - Gold GTfour God
Re: Towels first 1/4 mile run!
WarTowels wrote:215,000 Miles on stuck internals
Stuck internals, well there is your problem right there!
-James
-James
YerRandO - Club Member
YerRandO wrote:WarTowels wrote:215,000 Miles on stuck internals
What problem? That it was running 10-15 PSI and did a mid 13?
Who cares about your reaction time, your not bracket racing it. The thing to worry about is your 60 ft.
Nice times BTW fer what it is.
Justin
1972 Corolla TE27
1972 Corolla TE27
2of81 - Established Member
2of81 wrote:What problem? That it was running 10-15 PSI and did a mid 13?
Just laughing that he put "stuck" when I'm sure he ment "stock"
-James
-James
lol, yes. I meant stock. I was in a hurry.
My 60 foot was something like 1.6s? I think. I need to pull out my slip.
Thanks guys though, I'm pretty happy with the times given what I've done.
-Greg
-Greg
2003 S2000
1985 300TD
1985 300TD
RedCelicaTRD wrote:Good times. Any reason you where running 45psi in the tires?
Quite frankly, I didn't know what I should run for optimal grip.
The max pressure on the tires is 51psi. So I thought 45 would be a nice happy medium.
-Greg
2003 S2000
1985 300TD
1985 300TD
nice time.was this on stock ecu with stock 440s?
Current 1992 teal st185- 2018 - in pieces trying to pit back together
90 black st185 - 2018 - sold 2018
90 black st185 -sold 2010?
rip: 92 white st185 @ 178k :(
alltracshoak - Gold Member
Not bad man!! I ran 13.3 @ 102mph on almost the same setup. I'm sure you could shave some time off somehow.
I was on stock USDM ECU, injectors, fuel pump.
12psi on TD06. I had 9.0:1 compression pistons though. But my clutch was slipping and I had low compression in one cylinder.
- vip09
that's a good time w/stock fuel, ecu & 16 yr old suspension + street tires.
you'll get better with more practice too.
what was your trap speed?
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley - All Trac Goddess
I personally would run a lower PSI in the tires but if it's working for you then keep it up. I would probably run around 25 to start and adjust from there.
- RedCelicaTRD
Don't feel bad about the reaction time.. I don't even try to launch right at the light. It doesn't mean a thing unless you are bracket racing.
That is an awesome 60' time!!! I've never gotten below 1.8. Guess I need some better tires because all I do is spin! Your trap speed looks a little low for 15psi. Overall not a bad run at all! Very respectable.
- vip09
Well it's not "really" 15psi, it really depends on what the turbo feels like doing.
And if it ever gets up to 15 it's only for a bit. It's generally more around 11.
Thank you for the kind words.
My next mod is going to be an EBC hoping that will steady out my boost, I'll set it to 14psi and put my tires down to 25psi and see if I can shave a few tenths off.
-Towels
-Towels
2003 S2000
1985 300TD
1985 300TD
