St165 Complete Headlight replacement
Postby 3sgte4me » Mon Jun 08, 2009 2:55 am
Been searching through multiple posts with people's different recommendations--at least on st185s..
What is the best replacement on an st165? --- I need them bright and clear, but NOT so it blinds the on coming car.
My house, my wife, even my right nut can disappear, but never again will I give up my Alltrac.
3sgte4me
Postby Dracov » Mon Jun 08, 2009 3:34 am
On a budget: Hella E-codes with Osram Silverstar H4 bulbs.
1988 Toyota Celica Alltrac
Dracov
Postby 3sgte4me » Mon Jun 08, 2009 5:15 am
Dracov wrote:On a budget: Hella E-codes with Osram Silverstar H4 bulbs.
Where'd you get the E-codes for the 165?
3sgte4me
part # or resource
Postby 3sgte4me » Wed Jun 10, 2009 4:28 am
Anyone have the part #s or a resource to find the Ecodes?
Dont know which ones to necessarily look for.......
3sgte4me
Postby Dracov » Wed Jun 10, 2009 8:58 am
Both the 165 and 185 use a universal 200mm rectangular sealed beam headlamp as it is, so it's pretty easy to find replacements that use H4 bulbs.
Here's a full kit actually. Two headlamps and two bulbs of choice, starting at $92 for the whole thing:
http://www.rallylights.com/detail.aspx?ID=744
Just put the bulbs into the housings, put the dust boots on, and replace it like it was an OEM sealed beam. 100% plug and play and with infinitely better night visibility
Dracov
Excellent
Postby 3sgte4me » Wed Jun 10, 2009 4:01 pm
This is really good info, and needs to be made a sticky.
Admin can you make the info presented here *sticky*?
Dracov wrote:Both the 165 and 185 use a universal 200mm rectangular sealed beam headlamp as it is, so it's pretty easy to find replacements that use H4 bulbs.
3sgte4me
Also the bulbs
Postby 3sgte4me » Wed Jun 10, 2009 4:04 pm
Also curious as to which of the bulbs you'd go with.....given the choice. (dont know if you had responded to that:
The H6054H
or the H6054J ?
3sgte4me
Postby Dracov » Thu Jun 11, 2009 7:55 am
I'd say the 70/65 set. That's already higher wattage than stock 60/55. Too bright may attract unwanted attention from LEO's. When I bought my 165 it was already converted to these housings but has a mismatched pair of bulbs. I'm gonna give Osram Nightbreakers a shot and see how they work.
Dracov
Postby **BETSY** » Thu Jun 11, 2009 3:24 pm
Guys, get yaself some Raybrig lights, lots better!
If you need help sourcing, let me know!
Steve Gillies
ST-165 88 UK ([color=red]BETSY[/color])
[url=http://i32.photobucket.com/albums/d30/steve-gillies/Betsy/RollingRoad005.jpg]377BHP 353Ib/Ft[/url]
UK
**BETSY**
Postby Meurz » Thu Jun 11, 2009 3:53 pm
**BETSY** wrote:Guys, get yaself some Raybrig lights, lots better!
Raybrigs are for RHD use only mate. :(
Turbocelica.nl
Meurz
Postby **BETSY** » Thu Jun 11, 2009 5:41 pm
AFAIK there is no lens on the Raybrigs, the front is clear plastic?
Steve Gillies
UK
**BETSY**
Postby Meurz » Thu Jun 11, 2009 5:48 pm
Yeah but the reflector which is sealed onto it is setup for RHD so for legal use (at least, here in NLD) you'd have to swap LHD reflector housings onto the plastic fronts and hope the lines in them (only a few, I know) don't affect the light pattern too much.
Turbocelica.nl
Meurz
Postby Dracov » Thu Jun 11, 2009 6:50 pm
Yeah, RHD lamps in the US would be a worse blinding hazard than putting a cheap HID kit in eBay diamond cut housings.
Dracov
Re: St165 Complete Headlight replacement
Postby nbx33 » Wed Sep 22, 2010 9:02 pm
I have actually used the Ebay cheap replacements as a quick fix for more light.
I spent 49 on aHID kit from HIDGATE no issues ever from his kit.
and bought those fake projector housings.. which the reflector got too hot and fell out. I since got these ecodes and there incredible. I do get the Hibeams from other drivers every now and then.
nbx33
Postby Mafix » Thu Sep 23, 2010 12:41 pm
currently using e code housings (autopal) with ddm tuning hids. i'm in love.
Users browsing this forum: CMS-GT4 and 2 guests
