new alltrac owner from vancouver bc
Postby Tw_04_randy » Tue Oct 23, 2018 4:41 pm
hey guys new to the alltrac game but not new to Toyota i am currently building an jdm st185 car is running and driving but need a lot of small parts to get body interior and suspension to where i want it here are the specs
made 340awhp on break in tune
-mcs motorsports forged 3sgte 2.2l stroker (cp forged pistons,eagle bearings,h beam rods,arp headstuds,cometic hg,hks 272 cams,hks cam gears,greddy timing belt,os valves,dual valve springs,shameless buckets etc
-mcs motorsports stage 2 superflow 3sgte head
-moroso high volume oil sump with baffles
-ko racing t4 turbo kit (46 trim) with tial wastegate and 3 ceramic coated downpipe
-sard 800cc injectors
-sard fuel pressure regulator
-walbro 255lph pump
-aftermarket fual rail
-pwr 8x10 water to air intercooler
-fluidyne heat exchanger
-greddy blow off valve
-ku engineering intake manifold with 80mm thottle body
-ported exhaust manifold
-external oil cooler
-aftermarket rad and fans
-msd blaster coils
-oil catch can
-Haltech e8 standalone ecu and custom harness
-st205 transmission
-act 6 puck clutch
-aluminium flywheel
-hks silent hi power exhaust
-whiteline 3 way adjustable sway bar
-cusco strut bar
-skyline r34 front brake conversion
-st205 rear brake conversion
-c's short shifter
Tw_04_randy
Re: new alltrac owner from vancouver bc
Postby underscore » Tue Oct 23, 2018 5:14 pm
Welcome! It's nice to see more members nearby.
Postby Rick89GTS » Thu Nov 08, 2018 7:10 pm
Welcome!
Rick89GTS
Postby transneptunian69 » Thu Nov 08, 2018 7:21 pm
Welcome fellow JDM owner!
1993 JDM ST-185 - The project
2001 Focus ZX3 - The daily
2017 Dodge Caravan - The grocery getter
transneptunian69
Postby Rick89GTS » Sun Jan 26, 2020 2:38 am
It's been a couple years, how's the build? :)
Rick89GTS
Postby GT4times2 » Thu Mar 26, 2020 7:59 am
Tw_04_randy wrote:hey guys new to the alltrac game but not new to Toyota i am currently building an jdm st185 car is running and driving but need a lot of small parts to get body interior and suspension to where i want it here are the specs
-walbro 255lph pump
-msd blaster coils
-oil catch can
-st205 transmission
-act 6 puck clutch
-aluminium flywheel
-cusco strut bar
-c's short shifter
Nice set up. Any pics?
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 (MRP) Gen4 swap
90 ST185 (Gray)
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
88 St165 (white)- 2020 Project
GT4times2
Return to New Member Forum
