Hey now! New member here.
Re: Hey now! New member here.
Postby simple » Wed May 12, 2021 8:54 pm
What an amazing week! First engine went in and now a correct color dashboard was at the pull and pay junkyard. Got a bunch of trim pieces as well.
simple
Postby Tippo » Thu May 13, 2021 11:04 am
Looks great! Stoked to see what you think about the 4th gen motor in the car. In the SW20 it's night and day.
1992 SW20 MR2 Turbo 4th Gen 3SGTE Swap. Aquamarine Pearl. Project "Prissy"
1992 ST185 Celica All-Trac Turbo. Teal Metallic. Project "Lazarus"
Tippo
Postby Alikazam » Sat May 15, 2021 2:53 pm
Love my 3rd gen engine :) needs a valve cover gasket, but dropped in 1 at a time head studs, and some cams, with better fuel system and stand alone plus KO Racing Street Brawler turbo kit, she's making plenty of poop :) Good luck with yours! I had to do same tank restore, but changed to Walbro 450 fuel pump while I was at it. :)
1990 Celica Alltrac - Emma
Gen 3 engine
KO Racing Street Brawler - Precision 5130 Turbo
KO Racing In Factory ECU Case - Link G4x ECU
327 AWHP @ 18psi - pump gas
Alikazam
Postby simple » Fri Jun 04, 2021 11:48 pm
Got a few more interior pieces from a GTS that showed up at the yard. Less sun damaged than mine
simple
Postby simple » Tue Jun 22, 2021 3:38 pm
I learned the blue and the dark blue are not the same color even when faded. Bummer because I like the lighter color. These seats are comfortable though!
simple
Postby simple » Fri Jun 25, 2021 6:27 pm
Finally got this fuel hose disconnected. Took heat and PB blaster to free the connections.
Unfortunately the plastic tube doesn't like the torch. This assembly is no longer available.
Now working on a really short 6AN fuel line. Like less than 6 inches after putting on the M14 adapters. Fun times
simple
Postby simple » Tue Jul 20, 2021 11:41 pm
Got a lot of the ST205 engine wired up and only left coolant and fuel disconnected. Newer dashboard is in. Feeling good.
Only question. The stock ST165 radiator fan doesn't fit with the ST205 turbo location. Anyone have a hint on what fan to put in that little spot?
simple
Return to New Member Forum
