timchase":28mabfp8 said:
The one I found was on hksusa.com. It is a 75 mm piping with a 125 inch tip which basically converts to a 3 in pipe and a 5 inch tip.
I am going to need to replace the stock exhaust at some point in any event as it is neary 18 years old.
I will pick it up and see how it goes.
Thanks for the tip on the intake. I take it the battery would need to be moved to the rear hatch, not sure I want to give up the storage space as this will soon be my daily driver.
yeah, thats the 3" hks "silent power" exhaust. as i said, mine is discontinued, so you'd only find it second hand. depending on the price, you might want to look into a custom 3" exhaust from the downpipe back. there is a shop in denver called street concepts, and im going to have them build a midpipe with a high flow cat for me once the car is 100%, since i already have a 3" downpipe and a 2.5" catback.
the battery doesn't take up much space. i have an optima redtop with bottom mount hold-down from ebay. its in the passenger side corner, and in reality, it doesn't take that much space. however, unless you have a hook up on materials, it will be kinda expensive. i got my entire relocation wiring and terminals for $20 from a guy i know in the springs, and a local guy who worked for interstate batteries got me a brand new optima for $100. i think the bottom hold down was around $60ish off ebay. it took a couple hours to run the wires since i ran them under the carpet in a way that no one could see them and i had to drill 3 small holes to mount the battery hold down. if you want, you could mount it a number of other places, if the battery is small enough, but considering how cold it can get in Colorado, and that its your daily driver, i wouldn't recommend a mini battery.
a straight intake is really easy once you get the battery out of the way. get a 3" peice of aluminum with two bungs welded on for the idle air and the PCV hoses. i would get them welded as close together at the center of the pipe as possible since you'll have to cut the pipe to the length you need, get a 2 3/4" - 3" coupler, a 3"-3" coupler and whatever cone intake you want that is adapted for the stock AFM (K&N, apexi, blitz, HKS, etc.). i like the apexi because its a dry element.
