Greetings from British Columbia!
I'm planning to buy a locally-listed 1988 Celica Turbo 4WD this weekend. Against all car-buying wisdom, I've fallen in love with the car before the deal has gone through and I'm looking for advice when inspecting the vehicle.
Here are some things that I've been told to check:
- rocker panel/floor rust
- strut tower rust
- compression check
- valve cover gasket for oil leaks
I'm wondering if the seller is hiding a major issue. He's put in new front struts and "lots of new suspension/brake parts", and body panels have been switched out because of rust too.
What would you recommend me to inspect? And should I also post my inquiry somewhere else?
I'll definitely go through the search bar for more research too but I'd love to hear more advice.
Many thanks,
- oacup
- strut tower rust
- compression check
Many thanks,
- oacup
