Hey now! New member here.
Re: Hey now! New member here.
Postby simple » Sun Sep 06, 2020 4:48 pm
Pulling parts from ST165 engine and transmission
PM if you need anything. Bottom end is broken. Everything else seems good. Well maintained car.
simple
Postby simple » Tue Sep 08, 2020 2:12 am
Just put a bunch of parts on eBay
simple
Postby simple » Sat Sep 19, 2020 8:26 pm
Old ST165 engine is stripped and new ST205 is on the stand.
Got a specialist tool to get the crank bolt off. Geez it is torqued down tight.
simple
Postby alltrac801 » Sat Sep 19, 2020 9:35 pm
How common is that center feed intake manifold on the 205 engine?
1991 Toyota Celica All-Trac White (239,000 miles)
1991 Toyota Celica All-Trac Black (163,000 miles)
alltrac801
Postby simple » Sun Sep 20, 2020 12:35 am
It is still left of center like the ST165 and ST185. The big difference is the intake runners being 4 big ports.
simple
Postby alltrac801 » Sun Sep 20, 2020 1:51 am
I'm not all that familiar with the 205 engines I thought they were all side feed intake manifolds unlike the 165 and 185
alltrac801
Postby underscore » Sun Sep 20, 2020 1:53 am
I believe you're thinking of the 215 and 246 Caldina engines.
Postby simple » Sun Sep 20, 2020 2:04 am
underscore wrote:I believe you're thinking of the 215 and 246 Caldina engines.
Otherwise known as Gen 4 and Gen 5 3sGTE engines. Sorry for the crap photo.
simple
Postby autojumbled » Mon Sep 21, 2020 7:21 am
alltrac801 wrote:I'm not all that familiar with the 205 engines I thought they were all side feed intake manifolds unlike the 165 and 185
All ST205 engines have centre-feed intake manifolds, just like 165 and 185.
Caldina (ST215) has the side-feed
autojumbled
Postby alltrac801 » Mon Sep 21, 2020 5:29 pm
Shit I had a brain fart and was thinking the 205 had the 4th gen :bangshead: I wasnt even thinking about the 3rd gen. My bad haha I'll keep my mouth shut for now.
alltrac801
Postby simple » Fri Dec 25, 2020 4:45 pm
Merry Christmas.
One fully restored gas tank going back in. Lots of $$ into this part. New fuel pump and all new gaskets. Tank was dipped and refinished. Pump assembly removed of its rust.
simple
Postby Tippo » Fri Dec 25, 2020 9:27 pm
simple wrote:Merry Christmas.
That is cleeeeeean, looking to do the same. It pays dividends to keep it in good shape because man are they hard to find now!
1992 SW20 MR2 Turbo 4th Gen 3SGTE Swap. Aquamarine Pearl. Project "Prissy"
1992 ST185 Celica All-Trac Turbo. Teal Metallic. Project "Lazarus"
Tippo
Postby simple » Sun Dec 27, 2020 12:40 am
Out with the semi functioning switch stalk and in with a fully functioning version.
simple
Postby esracing » Fri Jan 01, 2021 3:21 pm
looking good keep it up. following
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby simple » Sun May 09, 2021 1:45 am
Finally got the ST205 engine in. What a tight fit. So much to do but my garage feels so much cleaner already!
simple
Return to New Member Forum
