Hey now! New member here.
simple
Active member
Well after taking a break from this project since October I finally got going again. I found a set of used ST165 shifter cables on eBay over the winter and installed them this weekend. Before I put them in I compared to the shifter cables I was having trouble with. Very obviously I installed one correct cable and one from likely a ST202 Celica. That was an idiotic thing to do on an otherwise trouble free swap.
Now with the correct shifter cables in and an upgraded shifter spherical bushing (PRIMEMR2) it feels nice and tight. Put the interior back together.
Next step is bleed the clutch, adjust the gas pedal to work with the ST205 accelerator cable, and clean up the misc wiring and modules in the engine bay. Then take it for it's first drive in 20 years!!!!
Dan McBoost
Member
Welcome to the forum!! Love the build too. White is kick ass on those.
One fully restored gas tank going back in. Lots of $$ into this part. New fuel pump and all new gaskets. Tank was dipped and refinished. Pump assembly removed of its rust.
I never noticed you mention who did your gas tank? I need to redo mine as well. Was is the place in Minnesota? If not, where please? TIA!
simple
Active member
Hey Dan! I had folks in Denver restore the tank. Small little outfit that usually works on hot rods. Hope you can find a similar place in Minnesota.
simple
Active member
Hey good to know I'm south of Denver, which place was it, the car I just got sat for a little while.
Spike Radiator (303) 762-7522
also if anyone needs air conditioning repair by the best call Julian at 303-254-6174
(BTW the best places in most big cities don't have fancy websites or crappy facebook pages. They get real work done and don't waste time on the internet like we do)
simple
Active member
In the long saga of "when are you going to be done with that Celica?"
Been working on the car a lot since the snow stopped falling. Last fall I had to remove the clutch hydraulic line completely to clean it out. Could not get a bleed to work as the fluid was clogged up in there. Fun times. Got a decent bleed on that and the brake lines which also had ancient fluid in them.
Here in the spring I thought it's time to get it on the road in my neighborhood and see how it feels. Well the clutch and the brakes aren't bled very well so that's sketchy. Runs pretty decent but idle went to shit and it died in the driveway on the way to the garage. Took apart the IACV and it was dirty but not clogged. Idled well without the WTA intercooler attached. Not as well with it on. Super sensitive to vacuum lines. Got it back on the road and anytime under load trying to get into boost the car bucks and shutters then goes into wicked limp mode. Now it dies soon after starting it. No check engine light. It's got to be the fuel. Changed the fuel filter (again) and the fuel coming through is still pretty brown. Awesome. I'll have to drop that fuel tank again. Get it restored again. Wish a new fuel tank was available. Getting closer...
Monachopsis
Member
When you get it running you have to cruise with roreri and I. We just did one and it was the time of my life! Got mega sideways on gravel
Top
