Another ‘88 ST165 is getting restored
Postby Driv3r » Mon Mar 09, 2020 11:05 am
Hi from White Western Canada,
After more then a year hunt for an 1988 All-Trac ST165, I finally got my hands on one.
My current plan is to bring it to it’s previous glory same as my 1986 MR2 AW11.
Most likely I will be looking to source a bunch of parts in order to bring it back to its past 100% original state and the first thing I will be needing is a good 3S-GTE gen1 block that i could use to replace the cracked one in the car.
At this point it doesn’t matter if is a complete motor, a short block or just bare block as long as it’s usable.
If you have one left around after your engine swap or you know anybody that has one please let me know.
Thank you in advance!
Alex :D
Driv3r
Re: Another ‘88 ST165 is getting restored
Postby simple » Mon Mar 09, 2020 6:18 pm
Awesome! I'm looking for the same thing here in the States. With how few there are the prices for Gen1 motors are high right now. Good luck!
simple
Postby Rick89GTS » Tue Mar 10, 2020 10:52 pm
Welcome to the joy & pain of All-Trac ownership! Is your 165 white? Post up some pics when you can.
Rick89GTS
Postby Driv3r » Tue Mar 10, 2020 11:53 pm
Rick89GTS wrote:Welcome to the joy & pain of All-Trac ownership! Is your 165 white? Post up some pics when you can.
Thanks!
it’s black with red interior.
Driv3r
Postby Rick89GTS » Tue Mar 10, 2020 11:59 pm
Looks straight and clean! Looks like it's been repainted? Instead of Gen 1 motor, have you thought about putting in the 205 motor?
Rick89GTS
Postby Driv3r » Wed Mar 11, 2020 12:18 am
Rick89GTS wrote:Looks straight and clean! Looks like it's been repainted? Instead of Gen 1 motor, have you thought about putting in the 205 motor?
I would like to bring it back to its former glory with its stock engine. If that completely fails I will place a newer 3SGTE
Driv3r
Postby underscore » Wed Mar 11, 2020 5:25 am
I'd do some digging around here to see if a later block would be compatible with the 165 ancillaries. That would hopefully give you an easier time finding one in good shape.
Postby Driv3r » Wed Mar 11, 2020 12:49 pm
I might have found an old ST185 short block. Not sure of it’s condition but at least I can use it to see how close or different is from the ST165 block. Sleeving might be another route.
The only problem is that I have to finish 2 other engine rebuilds before I start going on this one.
Driv3r
Postby hoys » Wed Mar 11, 2020 4:30 pm
I've got a ST165 long block sitting in my garage. Let me know.
hoys
Postby Driv3r » Wed Mar 11, 2020 10:52 pm
hoys wrote:I've got a ST165 long block sitting in my garage. Let me know.
I just send you a PM, Thanks!
Driv3r
Postby RedCelicaTRD » Sat Mar 14, 2020 1:42 am
AN ST185 can be swapped in without much hassle. The mounts are the same. The 185 has a different oil cooler setup which also means a different turbo oil feed. Other minor differences. In the end it all depends on how original you want it to be.
Postby Driv3r » Sat Mar 14, 2020 2:35 am
RedCelicaTRD wrote:AN ST185 can be swapped in without much hassle. The mounts are the same. The 185 has a different oil cooler setup which also means a different turbo oil feed. Other minor differences. In the end it all depends on how original you want it to be.
Ideally I would like to have it 100% stock and I am also currently exploring the option of Installing sleeves in order to preserve the original block, however it will all depend on the dollar amount. Tomorrow I am heading to my machine shop to pickup a block I droppers 2 weeks back and I will try to find out what would be the cost for such an endeavour.
Driv3r
Postby 93celicaconv » Sat Mar 14, 2020 5:20 pm
Don't know what your budget is at for what you intend to do, but here is a Gen 1 3S-GTE available from an eBay dealer:
- https://www.ebay.com/itm/1986-1989-Toyo ... Swu1FeUW31
93celicaconv
Images: 26
Postby Driv3r » Sat Mar 14, 2020 11:23 pm
93celicaconv wrote:Don't know what your budget is at for what you intend to do, but here is a Gen 1 3S-GTE available from an eBay dealer:
That is great find however I can probably revive my engine for about 1k. I just had a chat with my machine shop today and most likely I can sleeve the block. The only issue is that i have 2 more engines to rebuild before I get to tear apart the gen1 3SGTE
This one just got dropped off the machine shop
Driv3r
Postby simple » Sun Mar 15, 2020 10:46 pm
I may be new to this platform but isn't this a high price for a Gen1 engine?
simple
Return to New Member Forum
Users browsing this forum: CMS-GT4 and 2 guests
