System 10 wiring
Andy
I believe if you open the amp up It'll show you what the pins are...
There are id markings on the circuit board.
Andy
Is there a reason the wiring diagram in the BGB (it's black & white, but it has the letter codes for the wiring colors) isn't good enough?
Actually found a color diagram for the 1990 Celica System 10. This is for USDM Celicas. The ST185 System 10 was the same as used in GT & GT-S models that were built with System 10. Let me know if this helps. Otherwise, I can get your the black & white version too.
  • 1990 Celica Radio and Player (w CD Player).pdf
