1989 Toyota Camry All Trac for sale $500
Camry All Trac, Previa All Trac
Postby iriaf2001 » Fri Aug 10, 2018 1:14 pm
Camry All Trac with 174K miles. Automatic transmission with 4 wheel drive. Power windows\door locks, cruise, moonroof(does not open). The following parts were new in 2012: timing belt, drive belts, front\rear crankshaft oil seals, new camshaft oil seals, new distributor cap\rotor\spark plug wires, new ignition coil, new exhaust mid-pipe and muffler. Has studded snow tires. Body is fair condition, paint is in bad shape and has some rust but seems to be no holes. Some minor issues include the passenger rear door will not open from inside or outside, moon roof does not open, blower motor makes a noise when turned on, no AC-do not know if it works. Does not run, it was running well until it just stopped and will not start but engine turns over. At one point it did start and run for about a day then will not start again and it did this a few more times until I could not get it to start anymore. No Check Engine Light but bulb is good. Good for parts or you can fix. You can also have a manual Celica All Trac transmission if you like. This transmission will need a rebuild. $500 Firm.
Send email to: sellmystuff@roadrunner.com
iriaf2001
Return to Other All Tracs
Users browsing this forum: Google [Bot] and 1 guest
