3sgte prizm ALLTRAC project!!!!!!
Camry All Trac, Previa All Trac
Postby cire626 » Tue Aug 13, 2019 9:45 pm
Started the car the other day after sitting for years. As of now as of now i have to remove the gt tranny and install the alltrac tranny.. I couldnt find an alltrac rear subframe complete so i went with the rav4 rear diff and axles. Has the same gear ratio and the wheel base is only 3/4inch wider than the prizm. I need to find rear spindles preferebly something easy to find
https://www.instagram.com/p/B1G1qf3Fsrf ... jfds8jkbxk
cire626
Re: 3sgte prizm ALLTRAC project!!!!!!
Postby fvkagi » Fri Aug 16, 2019 3:30 pm
cire626 wrote:Started the car the other day after sitting for years. As of now as of now i have to remove the gt tranny and install the alltrac tranny.. I couldnt find an alltrac rear subframe complete so i went with the rav4 rear diff and axles. Has the same gear ratio and the wheel base is only 3/4inch wider than the prizm. I need to find rear spindles preferebly something easy to find
I have a spare all-trac rear subframe if you still want one. I am on Long Island, NY. It is a complete rear drop out.
fvkagi
Return to Other All Tracs
