"other" alltrac??
Camry All Trac, Previa All Trac
Re: switch
Postby wizzards581 » Thu May 24, 2007 12:48 am
GMan wrote:> wizzards581
> Location: Nor Cal
> Posted: Sun May 20, 2007 12:51 am
> camry alltrac are manually switch 4wd (auto),
The switch is to disable the awd for towing.
Not to be used for daily driving. But I have done it.
It does not disengage the center diffs.
> dont know about 5spd manual.
There are some around.
A few have been converted to All_trac turbo & 5spd. :-)
Regards;
maybe i need to read my owners manual about that switch. i never knew its for towing. if its to disable awd, its going to run fwd? rwd?
did the 5spd manual have the switch for awd?
-03 matrix XR
wizzards581
towing.
Postby GMan » Thu May 24, 2007 9:18 pm
> wizzards581
> All Trac Club Member
> Location: Nor Cal
> Posted: Thu May 24, 2007 12:48 am
Both. It just unolcks the center diff, -to allow slippage.
I still would not want to tow it far.
I dunno, I got an auto AT Camry.
Regards;
GMan
Postby celicaGTS_T » Fri May 25, 2007 1:25 am
Is it true there is a ST207 made? Maybe thats another 'alltrac'... :shrug:
celicaGTS_T
Curren
Postby GMan » Tue May 29, 2007 12:10 am
> celicaGTS_T
> Location: Riverside, CA
> Posted: Fri May 25, 2007 1:25 am Post subject:
yes there is an ST207. It is a Toyota Curren.
http://english.auto.vl.ru/catalog/toyota/curren/
http://cgi.ebay.co.uk/Toyota-Curren-Cel ... dZViewItem
http://www.pistonheads.com/sales/153825.htm
No, you are Thinking of an ST205. aka GT4, we never got the model in the US.
( Legally, a few grey area imports made it in + A few 4wd conversions... )
http://www.pistonheads.com/sales/176664.htm
http://www.6gc.net/index.php?action=members&itu=696
www.Google.com does wonders for searches.
Regards;
GMan
Postby WarTowels » Fri Jun 01, 2007 6:35 am
^I think it's safe to say at this stage that pretty much everyone has heard of Google.
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby not12listen » Thu Sep 20, 2007 3:07 pm
well, if we're counting JDM cars as well, there was an AllTrac Supra. it used the 1G-GTE engine.
http://www.supramania.com/forums/showthread.php?t=2409
2.0L, straight 6, DOHC... yep. and AllTrac Supra...
not12listen
AWD/4wd ?
Postby GMan » Fri Sep 21, 2007 2:13 am
> not12listen
> Location: Pleasanton, Ca
> Posted: Thu Sep 20, 2007 3:07 pm Post subject:
No problem.
All Supras were inline 6 striaght cylinders. Kind of Hard to
add 4wd ?
Where oh where does it mention awd/4wd in that thread ? :shrug:
If you have a source I'd Love to learn more.
Plus All_Trac was a US market term only.
Celicas were GT4s in japan and Europe.
There was an Interesting JDM 4wd V8 Aristo (GS400 USDM) with an auto tranny only.
Regards;
GMan
Postby not12listen » Fri Sep 28, 2007 7:34 am
ya know... i have seen an alltrac supra, but it was ONLY used in safari rally. unfortunately, i cant even find any record of that. :(
then again, toyota DID create an AWD MR2 (MKI style) that was apart of the Group S Rally series.
not12listen
Postby Gary ST165 » Fri Sep 28, 2007 12:27 pm
electronic parts catalogue shows GA70 to be RWD...... deffo no 4WD alltrac Supra :?
The TTE supras (safari spec) were also rear wheel drive:
Indeed the Group S "MR2" is 4WD and one of only 12 prototypes built with both transverse & longitudinally mounted 503E lumps..
ST165 turbo 4WD
Gary ST165
Postby not12listen » Fri Sep 28, 2007 2:30 pm
ok... i've done lots of reading and searching on the Group S mr2 and the Safari Supra...
where did you get those pictures!?
and, is that the famed 503e in the mr2?
not12listen
Postby not12listen » Fri Sep 28, 2007 5:57 pm
one of the few things that i truly hate about toyota...
we, in the US, were not offered the same 1999 Corolla as the UK. i want that specific Corolla with the TTE body kit, and i'd go thru the hell of making it into a true AllTrac. :)
but no... the US gets the 'low end' toyotas. argh!
and, while i understand that the Matrix is basically the UK Corolla, in my eyes, it just isnt...
not12listen
Postby Gary ST165 » Fri Sep 28, 2007 6:15 pm
TTE pics were hosted on: http://northwestmr2.com/incoming/dutch/ ... l%20Images
Group S "MR2" featuring the 503E >> pics taken at The Goodwood Festival of Speed 2007
http://www.imoc.co.uk/forums/viewtopic. ... highlight=
and my photobucket album:
http://s32.photobucket.com/albums/d38/skintbinlid/503e/
http://s32.photobucket.com/albums/d38/s ... TE%20grpS/
http://s32.photobucket.com/albums/d38/s ... OS%202007/
hth ;)
i've got loads of TTE pics on my photobucket account.
http://s32.photobucket.com/albums/d38/s ... OS%202006/
The above AE111 Corolla was only available in 2wd guise. TTE took full advantage of the new WRC regulations and built a formidable rally car. Something like 400 man hours plus to strip it down and re-engineet it to 4WD WRC spec. iirc The last of the TTE Corolla's used a turbo charged Lexus IS200 3sge beams engine / block ...
http://www.rallycars.com/Cars/Toyota_GT ... a_WRC.html
ST165 turbo 4WD
Gary ST165
Postby not12listen » Fri Sep 28, 2007 6:34 pm
OMFG.................................
WOW. i'd slaughter many mindless humans to sit in that MR2... let alone drive it... :)
obsessed? yeah. just a bit. :) i've honestly been thinking of how to 'create' an AWD mr2... the transmission and 'front' differential would be the most difficult piece as far as i can recall.
i guess that would help to explain why the 503e is reserved from the 3sgte, as far as placement of cylinder 1, etc. if i'm not mistaken, the rotating direction of the crank, cams, etc is also reversed.
that would almost be like having 5 or 6 'reverse' gears and 1 'forward' gear, in comparison to the standard alltrac setup.
oh yeah, and more than any other car on this planet, i want to own/drive an AWD Corolla with the full TTE body kit. basically, the WRC car. :)
and yes, it would be my daily driver, and i would work on that car nearly every weekend with a smile on my face and bloodied hands. :)
i want that car more than the Lotus 7, Elise or Exige. the McLaren F1 LM is very nice, but not my taste. the Bugatti Veyron is a technical super achievement, but i think it's hideous and 1000hp from a 16 cylinder, quad turbo engine does not impress me (*cough* 503e *cough*). even the Mercedes 190 Cosworth edition doesnt hold a candle to that Corolla...
not12listen
Re: towing.
Postby BlaznToyo » Tue Dec 18, 2007 7:30 pm
> Location: Nor Cal
Regards;
I have an 88 CAMRY ALLTRAC 5spd and it has the button for locking the center diff.
BlaznToyo
Re: AWD/4wd ?
Postby solarinsocal » Thu Dec 20, 2007 2:39 pm
GMan wrote:> not12listen
add 4wd ?
Regards;
Skyline GT-R straight six AWD.
solarinsocal
Return to Other All Tracs
