camry alltrac 3sgte swap
Camry All Trac, Previa All Trac
Postby CAMRYGT4 » Fri Nov 16, 2007 3:39 am
So its been a long time since I posted on this site but the swap is finally done, ok the swap was finished in July.
This is a list of mods done to the car. 3sgte swap, ATS racing throttle body adapter, cold air intake, NGK iridium spark plugs, ARP head studs, Greddy Profec B boost controller, Walbro 255 lph fuel pump, TRD spark plug wires, TRD steering wheel, TRD shift knob,custom intercooler with custom plumbing, 3 in down pipe, full 3 in mandrel bent exhaust with Magnaflow muffler, 17 in Motegi wheels with 215/40/17 BFGoodritch g-Force T/A KDW-2 tires, sprung hub six puck stage 3 clutch, cross drilled and slotted rotors, custom stainless steel braided brake lines, polyurathane control arm bushings, custom spring and sleeve kit, car lowered 2in(all my picts were taken before the car was lowered), strut tower brace, HID head and driving lights, Alumapro sub, Pioneer DVD navigation system, leather interior, revers glow gauges, battery relocated to the trunk. I think thats it.
I attached some pictures but there are a lot more in my gallery.
(178.78 KiB) Downloaded 135 times
(56.84 KiB) Downloaded 109 times
CAMRYGT4
1988 Toyota Camry
Running ?
Postby GMan » Wed Nov 28, 2007 10:19 pm
How is the car running ?
Nice to see another AT project completed. :D
GMan
Re: Running ?
Postby CAMRYGT4 » Fri Nov 30, 2007 8:00 pm
GMan wrote:How is the car running ?
The car runs great! I drive it to work almost every day. It drives really well, in fact it came out better than I had hoped. The only bad thing is it gets 17 MPG instead of 28 but it was worth it.
CAMRYGT4
1988 Toyota Camry
Postby zblu81 » Wed Dec 12, 2007 3:58 pm
I like it! If I could find a rust free one in Michigan I would start my own project.
Did you use the Celica transfer case or the Camry one? Was the Camry originally a 5-speed? I had a FWD 5-speed Camry that had a much higher 4th and 5th gear.
I think you'd see a good increase in power with a better intercooler set up.
It doesn't look like you'd get much flow over it the way it is in the pics.
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
3" Exhaust, RC intercooler, ATS TD06-20g, stage2 clutch
zblu81
Postby CAMRYGT4 » Wed Dec 12, 2007 6:11 pm
zblu81 wrote:I like it! If I could find a rust free one in Michigan I would start my own project.
Yes the camry was originally a 5-speed and the transfer case is the camry unit with the locking center diff.
The intercooler isn't bad but it isn't great, it has a big fan under it that helps. I was going to put louvers in the hood but right now Im trying figure out how to put in a front mount with out loosing my AC, but the AC may have to go.
CAMRYGT4
1988 Toyota Camry
Postby etantshi » Wed Dec 12, 2007 7:07 pm
That's not bad. You could always make a side mount instead of a front mount.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby CAMRYGT4 » Thu Dec 13, 2007 1:06 am
etantshi wrote:That's not bad. You could always make a side mount instead of a front mount.
A side mount intercooler was the plan from the start but there wasn't any room. However I was able to fit my air filter down there. The other option is to modify an Accord body kit. All the body kits for this year Camry look like garbage.
CAMRYGT4
1988 Toyota Camry
Postby BlaznToyo » Tue Dec 18, 2007 7:22 pm
Nice CAMRY ALLTRAC, very clean looking...i have an 88 that i just bought as my project car. Did you rebuild the your AWD tranny?
BlaznToyo
Postby CAMRYGT4 » Tue Dec 18, 2007 7:45 pm
BlaznToyo wrote:Nice CAMRY ALLTRAC, very clean looking...i have an 88 that i just bought as my project car. Did you rebuild the your AWD tranny?
I didn't rebuild the transmission but I should have. I'm going to put forged internals in the engine next month and I will rebuild it then. The trany works fine but it has 180000 miles on it.
CAMRYGT4
1988 Toyota Camry
Postby BlaznToyo » Tue Dec 18, 2007 9:50 pm
yah thats a lotta miles...as for a repacement, why u didn't use a 185 tranny? didn't it come with the engine? or you wanted to keep the center diff locking feature of the Camry tranny.
BlaznToyo
Postby zblu81 » Wed Dec 19, 2007 6:33 pm
Do you have a tachometer? was is your RPM when cruising at 70mph?
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
zblu81
Postby silence » Wed Dec 19, 2007 7:08 pm
very cool!!!
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby CAMRYGT4 » Thu Dec 20, 2007 6:30 am
zblu81 wrote:Do you have a tachometer? was is your RPM when cruising at 70mph?
I do have a tach. I cant remember exactly but its high, between 3500-4000.
CAMRYGT4
1988 Toyota Camry
Postby CAMRYGT4 » Thu Dec 20, 2007 6:35 am
BlaznToyo wrote:yah thats a lotta miles...as for a repacement, why u didn't use a 185 tranny? didn't it come with the engine? or you wanted to keep the center diff locking feature of the Camry tranny.
I do have the celica trany and I may use it but I need an st185 rear diff and different front shafts. The locking center diff really only makes a difference in the snow, so its nice but I dont have to have it.
CAMRYGT4
1988 Toyota Camry
Postby Rick89GTS » Thu Dec 20, 2007 7:10 am
A sleeper Camry, nice work :smokes:
Welcome to the board.
Rick89GTS
Return to Other All Tracs
