Toyota Caldina ST215
Camry All Trac, Previa All Trac
Re: Toyota Caldina ST215
Postby celicast184 » Sat Apr 28, 2012 4:12 am
jecs, if ur using the st205 ecu on st215 engine, u will need to run st205 distributor/ignitor/st205 wire harness/coil/sparkplug wires/valve cover/. i would say jus buy a st205 engine set instead of converting 215 to 205.
I <3 MY ST214
celicast184
Postby JeCs » Tue May 01, 2012 12:45 pm
celicast184 wrote:jecs, if ur using the st205 ecu on st215 engine, u will need to run st205 distributor/ignitor/st205 wire harness/coil/sparkplug wires/valve cover/. i would say jus buy a st205 engine set instead of converting 215 to 205.
I used to have an ST185 engine I made the electric part ST205 distributor/ignitor/st205 wire harness/coil/sparkplug wires so when I got the ST215 motor It was running with a Power FC ecu. I haven't bought the Power fc ecu, just the motor, I decide to use the motor with ST205 distributor/ignitor/st205 wire harness/coil/sparkplug wires/valve cover/ because thats how it was working before and find the others ST215 parts is a little bit hard here, but the engine was in a good price $$ and I did it, it's woring very nice. I think I going to a Dyno on this month if is like that I gonna tell you the results ;)
From Dominican Republic
JeCs
Return to Other All Tracs
