i have had a problem with the rust on the driver side rocker pannel and driver side rear quarter and need the part #'s. does toyota make a section for the lower quarter panel?
Take your chassis code / VIN plate info to your local Toyota dealership
Ask the parts desk man to search his EPC using ST185 part name codes PNC# 61612 (LH) & PNC# 61412 (LH). This will then bring up the same diagram for your LHD widebody. Only he can tell you how much these parts will cost brand new...$$$
i did the search on www.1sttoyotaparts.com and it was saying that the part was not found? did not try the toyota stealership yet. anyone have to purchase body panels before?
