So I was taking the old exhaust off aaaannd....
General Chat
Postby Turbo Lean » Thu Jun 26, 2008 11:06 pm
I broke two of the studs on the bottom of the downpipe, and since they are threaded in, I just punch them out. GREAT!
[img]http://img.photobucket.com/albums/v124/alltrac1993/barptps1.gif[/img]
1990 Celica Alltrac More $ less power
1999 Acura TL
1993 Civic Turbo 385hp 280Tq Less $ more power
Turbo Lean
Postby Rick89GTS » Thu Jun 26, 2008 11:51 pm
One of the few things that make our lives easier when working on the All-Trac
Rick89GTS
Postby Turbo Lean » Fri Jun 27, 2008 12:59 am
The only good thing about this is that now i have a reason to buy a downpipe.
1999 Acura TL
Turbo Lean
Postby TimmyD » Fri Jun 27, 2008 12:49 pm
"Easier" and "working on an alltrac" don't seem to fit in the same sentence. A friend of mine that helps with lots of the work on the car is always amazed they could rally something so complex to take apart and fix.
Its not an oil leak... Its sweat from all the horse power!
1991 Celica GT4 RC #236
TimmyD
Postby Hotrodhendrix » Fri Jun 27, 2008 12:52 pm
The rally cars were new at the time so the didnt have all these issues we have... I second the only good thing is now you have to get an aftermarket downpipe. :)
Postby alltracman78 » Fri Jun 27, 2008 4:02 pm
Man, you guys are crazy, I wish most cars were as easy to work on as the Alltrac.
Try doing plugs or the valve cover gasket, or valve seals on the rear bank of almost any FWD V6, or a broken stud on either bank, or pretty much anything on most domestic FWD V6.
Or an oil pan on a 2.7 Tacoma [have to pull the trans AND the engine], or anything on the rear cylinders of a newer Camaro/Firebird, or resealing the timing cover on a 3.5 Toyota V6, or a bajillion other things.
The only things that are truly hideous are tightening the pwr steering belt and most things on the underside of the intake manifold.
Rust and broken bolts happen on any 15+ year old car, it's not an Alltrac specific thing.
Postby Hotrodhendrix » Fri Jun 27, 2008 5:24 pm
+1 trust me......... Im also a 3000gt VR4 owner...... The alltrac has nothing on the VR4. :doh:
Postby Nitro_Alltrac » Fri Jun 27, 2008 9:19 pm
+2. Having worked on a multitude of cars over my 42+ years (yes, I am old! :D ), the All Tracs for the most part aren't that bad. Age and prior care has a lot to do with the issues that we have. Although, I am inclined to believe that Toyota did use a lot of soft bolts on our cars. As some of you have heard from me before, I have had bolts break off that didn't have any load on them. Other than that, I can't complain much.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby etantshi » Sat Jun 28, 2008 9:25 am
Never really had any major complaints working on the AT. I've had easier cars to work on and I've had harder. Most of my biggest issues are with the car specifically being from wisconsin.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby bloodMoney » Sat Jun 28, 2008 5:04 pm
^^^^^ +1!
I will never buy another car from Wisconsin again... The rust on this thing is terrible!
On topic: I totally agree with hotrod, nitro and alltracman on this... The 94 del sol that I've been helping a friend with was a total bi&*h. We had to cut the lower ball joint in half to get them out. And that's just a small example...
~bloodMoney
88 ST165 'Patty'
90 ST185 'Ellie'
'96 GT "Abby" ~ RIP 11/17/2013
'96 GT 'vert "Lily" ~ RIP 08/22/2015
'04 LS430 "Alice"
'98 GS400
bloodMoney
Postby Nitro_Alltrac » Sat Jun 28, 2008 8:29 pm
[quote="bloodMoneyThe 94 del sol that I've been helping a friend with was a total bi&*h. We had to cut the lower ball joint in half to get them out. And that's just a small example...
~bloodMoney[/quote]
Wow! That is a total b#@ch! I've never had to cut a ball joint up.
Mike
Nitro_Alltrac
Return to Club Chat
