newb question about valve lash and adjustments
General Chat
Postby alltracshoak » Sat Jul 19, 2008 2:59 am
ok, im in the process of a shimless bucket conversion. i did some measurements with the feeler gauge. i got the measurements of the one that can slide in. then i took off the guide and the shim and measure those with a micrometer. so is this how to calculate the right shim/shimless bucket size i need?
measurement of valve lash +- (depending of the correction i need)shim size+ guide = shimless bucket size i need?
thanks, this is my first time doing it so need a little bit of help.also, what are the min-max clearance of the valve lash on the intake side and on the exhaust side in in???
90 st185 - 2018 -
90 st185 -sold 2010?
rip: 92 st185 @ 178k :(
alltracshoak
Postby Balagast » Sat Jul 19, 2008 5:18 am
There was a write up done on it I believe if that helps you out a bit.
Here it is actually: http://alltrac.net/phpBB2/viewtopic.php ... conversion
1990 All Trac - Red (Down but hopefully not out)
Balagast
Postby Corey » Sat Jul 19, 2008 7:17 am
also, max/min clearances are in bgb
Corey
Images: 50
Return to Club Chat
