edmonton_oiler16
New member
Is it possible to get your car tuned to accept a lower octane? If there is what are the different ways?
No its probably alright as long as the pump definitely works and the lines etc are not clogged up with crap. If it has had a coolant change in its life it should be ok. They tend to form a brown liquid with chunks after a long time :smokes:edmonton_oiler16":axvwtgzb said:would you replace the water to air one with a ata one?
Celi-GT4":2qkim5to said:Can you get e 85 in that region? If you can try swapping in some 550 injectors and running that. You will not detonate and pick up 20 free ft/lbs. I love the stuff
