Trumanpriest
Member
The pin which comes from the green speedometer connection which goes into the back of the speedo cluster is broken off. Does anyone have experience fixing this? Is it (hopefully modular) and I can replace just a section of the cable which goes into the guage cluster or do I have to replace the whole blasted cable from the transmission? Thank you in advance.
