ST165 Hubs
Rick89GTS
New member
Hey Magroo, it says it doesn't fit the 1988 Celica Alltrac, so I'm not so sure they are the same part number now.... :shrug:
The last time my hub went i went to the Toyota dealer and they cross referenced it to tell me the models that are the same. There were a few models, including off Camry which had readily available stock
Rick89GTS
New member
Hey Skag, the 1987-199 Camry hub is part number 43503-32010. Lexus also used it but dealer is saying both those are no longer available.
*The difference is the ABS hub has a toothed gear around the hub, other than that (and ABS sensor), they are the same as the non-ABS hub.
Top
